Siemens xl 1400 washing machine will not wash
Lets water in drum will not rotate also will not spin
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Posted on Feb 15, 2007
SOURCE: hoover vision hd 1400 washing
I had the same problem. The machine would wash but not drain and the time savers button would blink. Turned out to an eye from a teddy blocking the pipe that enters the drain. I hope this helps.
Posted on Mar 16, 2009
  • 127 Answers
SOURCE: Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: SIEMENS XLM1400 WASHING MACHINE DOES NOT SPIN
siemens xlm 1400 washing machine fills with water but wont wash
Posted on Jun 04, 2010
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
Siemens xlm 1400 will not rinse clothes, it makes noise but the drum will not rotate eventhough it will turn by hand.
your motors drive brushes need replaced
so look to use the model number in EBAY
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xxlm+1400+brushes.TRS0&_nkw=xlm+1400+brushes&_sacat=0
i used the search string
'xlm 1400 brushes'
and they are quite easy to replace..
it may do a whole wash cycle and count down etc just wont spin or move the drum with heavy water laden clothes
goes eeeeeeeheheeheh but no drum rotate
so
you can drain the machine only
lay the machine down with the soap drawer away from the ground
then it wont leak
two screws and one power clip removes the brushes
from the main motor {the one with the belt that drives the drum}
their are two brushes one each side
so 4 screws
and replace both ..
so...
good times
let us know the size of the brushes left
they should be like new 2.5" - 3" long
if they are less then 1.5" replace them
this is the issue
the main advice is not to use it just now
till you check the motor brushes
as this type of fault can further damage the motor
so .. dont use it till you check / replace the brushes as the intermittent contacting will damage the motors stator {the bit the brushes make contact with}
Aug 19, 2014 | Siemens Washing Machines
Washing drum not rotating
More than likely belt gone, otherwise the motor has gone.
Apr 06, 2014 | Russell Hobbs RH1042 Frontload Washing...
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
