Question about Grilling
Barbecue spares for Bondi gas Barbecue
Burners corroded need replacements
  • 770 Answers
SOURCE: no gas flow from barbecue
Yes, if you have gas flow from your cylinder, then nothing when you turn on the valve on the grill..(You should hear...and smell the gas), then the problem is either in the regulator assembly or in the valve. Both items are cheap and easy to replace and parts are abundent at most hardware stores.
Posted on Jun 19, 2009
venexcsd
  • 1185 Answers
If you used a power washer you may have driven rubbish into inlets for the burners, or as my collegue has already pointed out, water.
If the BB is empty then turn it upside down onto some newspaper and see if you get a water discharge..
The gas is normally supplied through a hole into the burners and is mixed with air on the way in so that it combusts out of the holes on the burner
If none of them are lighting I would do the upside down bit first , if that does not fix it then start looking at the gas inlets
  • 60 Answers
SOURCE: I have a 5 burner Patio Range barbecue. I can
you probably need a hose and regulator
Posted on Aug 17, 2009
  • 34 Answers
SOURCE: Mice in our barbecue grill. What to do?
Is this a problem all the time or just in storage? If it is in storage make sure they have not place to climg on to get in. Also in storage you can put steel wool in the bottom openings and this should keep them out.
You can also put mouse poison around the base while in storage.
If it is a problem during normal use make sure they don't have anything close by that they are using to climb aboard.
Posted on Apr 17, 2010
DeBruce
  • 145 Answers
SOURCE: I moved to a house with Ducane Stainless Steel Gas
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Posted on Apr 29, 2010
Barbecue won't stay lit
make sure the propaine is not to low and the burner orafice is clean
Oct 13, 2014 | Char-Broil CharBroil Master Flame Gas...
I just hooked up my new tank to my barbecue grill, than turned on grill and tank,but no propane is comming out of burners. It is 30 degrees outside.
This happens no matter how cold it is outside, First turn the tank off, then turn the barbecue grill burners on for a couple of minutes with the top opened to vent out any trapped gas, close the burner knobs to the off position and slowly open the LPG tank valve to 1/4 turn, then try restarting the grill in the regular fashion. sometimes we cause a vapor lock situtation in the regulator by turning the grill on first before opening the LPG tank valve, the newer tanks are supposed to detect a freeflowing valve and close themselves off internally. This should remedy the issue.
Jan 25, 2011 | Garden
My Char Broil gas grills flame is taller than it should be( not blue at all anymore) and make the food smokey?
You need to clean the burners/pathways, its not getting enough oxygen and the flame is starved.
Sep 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Aug 16, 2009 | Grilling
No gas flow from barbecue
Jun 19, 2009 | Char-Broil CharBroil Master Flame Gas...
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Bunners do not get hot
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Grilling Logo
336 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
