Question about GE 21095GE2 Cordless Phone
Phone battery won't recharge
My GE digital phone model 21095ge2-a won't recharge the handset's battery any longer. Within about 1 minute of use, it starts to beep, so I now have to use the speakerphone. The batteries appear non-standard, so I don't know what to buy to replace them or where I could find them. Could you please give me some advice?
SOURCE:
SOURCE: GE Model 25952 Series 5.9 GHz Handset Speakerphone
take the phone back to the store and get a new one
Posted on Mar 14, 2008
  • 3 Answers
SOURCE: New Voice Mail flashing light
What worked for me was to call my phone from another phone and leave myself a voicemail. I then went in and retrieved and deleted that voicemail. Once I hung up from my voicemail service my handsets reset about 10 seconds later.
I hope this helps!
Posted on Jun 05, 2008
Ersinnl-hotM
  • 27 Answers
SOURCE: GE digital 6.0 cordless phone with 411 google
first : go through settin up your phone with the manual( as much as im directing to manuals that much im staying out of my own way ) :) succes
Posted on Oct 22, 2008
leroyal
  • 2120 Answers
SOURCE: retrieve messge via 'non-base' handset while using speakerphone of base
No. Handsets must be inactive.
Posted on Nov 06, 2008
  • 6 Answers
SOURCE: registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Posted on Jan 13, 2009
My GE cordless phone Model No. 28112ee3-a is not functioning and it keep beeping. I once found a code to stop it from beeping. can anyone help?
The GE 28112EE3-a was made by Thomson with the GE name. The manuals for most of these phones are available here: http://www.home-electronics.net/user_guides.asp . The direct link to the manual is http://www.home-electronics.net/USER-GUIDES/28112_DOM_EN_CL_IB.pdf .
What type of beeping are you hearing? If you are hearing a beep every seven seconds from a handset, the solution is to recharge the battery. If the battery won't hold a charge, then replace the battery with a 5-2721 Nickel-metal Hydride battery.
The handsets can also beep for about 2 minutes if another handset or the base pages them. This is a locator tone. Just press the Talk/Call Back button or the Tone/Exit button on each handset.
I hope this helps.
Sep 21, 2014 | Thomson GE Cordless Telephone 27995GE1
The photo slide show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed the reset button, but it...
1/15/09
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Dec 30, 2009 | GE Lands Phones
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
21095GE2-a user manual
I have the manual and can scan or fax pages if you want. Contact me if you still need this at: twoeyes4you@yahoo.com
My system just quit allowing me to listen to messages and all three batteries quit. I'll probably have to get a new phone system.
Let me know if you need handsets and cradles too, I have 3!
Judy
Aug 26, 2008 | GE 21095GE2 Cordless Phone
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
GE handset registration?
You may need to "reset" the whole system1.gif. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in batteries first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger. (If the new battery is not charged yet, then you will have to charge it first!)
Dec 31, 2007 | Uniden Cordless Phone
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
GE 21095GE2 Cordless Phone Logo
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
