Question about Lite On SOHD - 16P9S Internal DVD Drive
Liteon HDD/DVD recorder/player
DVD Drive does not open the door and also it does not recognise blank DVD's (any make).
I am looking for a soution or a replacement drive Model No. DDW813SO7C
Any hlep will be appreciated.
Thanks
Lite-on dvdrw in model HD-A760GX will not recognise dvd disc. KEEPS STATING TO INSERT BLANK
Posted on Jan 29, 2009
LITE ON HD-A740GX ONLY HAVE DIGITAL SIGNAL HOW DO I TUNE IN CAN I TUNE IN
You must connect a digital TV box between your arial and your Liteon, so the arial cable goes into the digital box, and use a SCART cable from the digital box to the Liteon. Then record using the SCART input on the Liteon. Another SCART cable can be connected from the Liteon to your TV, so you can view what you have recorded.
Apr 30, 2012 | Lite On HD-A760GX DVD Recorder / HDD...
Where can I get repaired in India LiteOn DVD Recorder ?
There is no ,LiteOn authorised repair centre in India. You can get in touch with a local repair technician for the same . Alternatively you send Liteon support people an email. Incase they have a tieup with an indian service & repair company.They would let you know.Find the link below
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=70
Thanks for using fixya
Proton
Sep 05, 2009 | Electronics - Others
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Jul 03, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Liteon 5045 problem in playing normal movie DVD's
The DVD drives are very unreliable and just get more temperamental with age. I replaced mine with a Lite-On SOHW-1213S. The DVD is too big to fit in the old ones place so it sits on top of the unit with the cable going through the slot, but it works brilliantly.
Nov 04, 2008 | Lite On LVW-5045 DVD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Liteon lvw-5045
If your DVD recorder can still access CD's the goto the following link and select your DVD recorder from the drop down list under audio/video and download the firmware file.
http://www.liteonit.eu/index.php?option=com_wrapper&Itemid=178
Write the file contained in the zip file to a CD and insert it into your DVD recorder. Follow the instructions in the user manual to complete the firmware update.
This should solve your problem.
Feb 19, 2008 | Lite On LVW-5005 DVD Recorder
Will not record onto blank DVD's from HDD on LVW-5045 HDD-DVD 160 gb
Hi Barry - I too have a Lite-on and was initially over the moon with it. For the last year or so I have been unable to "read" disks and was just using it for the hard drive for recording - but this weekend my father in law had the exact same problem occur to his Lite-on and he bought a dvd cleaner (£5) - used it and it solved it - So I tried it and presto mine is reading and writing fine again - I was so chuffed - need to share this simple info just in case its a simple "dust" problem for anyone else that is having reading problems. DVD cleaner not just a CD cleaner as DVD cleaners have two brushes on it.
Jan 02, 2008 | Lite On LVW-5045 DVD Recorder
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Lite On SOHD - 16P9S Internal DVD Drive Logo
301 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
