Marantz pm 4400
Cuts to mute
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: I have a marantz integrated
please disconnect loudspeaker one by one until the problem is goen -and fix the bad one by change the cabel first and the speaker second if all above does not solve the problem send your amp to service center to repair.
Posted on May 28, 2008
robotek
  • 1512 Answers
SOURCE: My Marantz PM-45 integrated amplifier
Hi HouseofBlues
The problem you are facing is the speaker protection is turning on to prevent the amplifier from damaging your speakers. It will need some service work done to it to prevent it from happening. I suggest you get it attended to sooner than later, as the problem will be caused by dry solder joints that will need to resoldered, or a semicinductor that is failing. If you are a gun with a soldering iron, you could do this yourself. Check about parts of the amp that runs hot, particularly transistors and resistors in the output stages. resolder all output transistors, and any parts that are mounted to a heatsink. Also focus on areas of the PCB that has discoloured. This is often where the problems occur.
I am more than happy to answer any other questions you may have about it, just give me a hoy :)
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 02, 2008
When i receive calls, I can hear them but the caller cannot hear me
Find the Mute button and turn MUTE back on. It cuts off the microphone so you can talk in private to someone without the caller hearing.
Jun 19, 2016 | Panasonic KX-TG1100 Cordless Phone
Marantz problems
The speakers are 8ohms. Always try using speakers 6 or 4ohms. For B&W 683 on PM 6004 is too low. You should go for PM 7000 or 8000 series to catchup with 683. Also when you increase the volume please decrease the bass as well.
You need 8ohm 55w to 90w or 4ohm 80w to 110w speakers.
Jul 20, 2014 | Marantz PM6004 Integrated Amplifier
Fn +f8 short cut key
Its for mute or unmute .. use fn key with up or down arrow key for controlling sound level..!!
Mar 07, 2014 | Acer Aspire 5610 Notebook
Mute light flashing
Is the amp otherwise functional? If not- check to make sure the speakers are hooked up and not shorted.
If it is functional and on AM or FM mode, it may just be the station signal is not adequately centered so part of the carrier is not being detected by the PLL and the between station muting is kicking in.
Oct 29, 2012 | Marantz PM-15S1 2-Channel Amplifier
Marantz pm 7200 loudspeakers do not cut off when headphones pugged in
Some amps have a button which you press to mute the speakers when the headphones are plugged in. Sometimes marked "Speakers on off". If it hasn't then a new headphone socket would not be expensive to fit. As long as the amp producers sound I don't see any future problems. The previous owner may have used the headphone socket a lot, and simply wore it out!
Jul 19, 2012 | Marantz Audio Players & Recorders
Volume Stopping Instantly
A few things to consider: if mute on the set is not on what about the box if you are using one?
Speakers could be switched off in the set.
There could be a internal / external speaker switch(not common but possible)
Sound on the set could be muted or turned real low or off.
if the image you see on the screen is there--either it is from the set or a box if one is used.
only a few things other than the sound circuit being bad will cause this--very few sets with actual no sound problems are around.
Apr 03, 2012 | Mitsubishi Televison & Video
No audio with uv10
I have Jensen uv10. I hooked it up and this no sound in a 94 f159 4x4
Mar 20, 2011 | Jensen Car Audio & Video
I am having radio and cd trouble. My radio in very low and the mute button don't change a thing but you can see that it is showing mute but the sound is the same. After cutting the switch off in about 30...
There is a voltage for sure generated by the mute switch or the controller to cut off amplification in the audio amplifier. Since you have noticed the mute on the display, This must be disabled to get the volume back. so the circuit must be traced to confirm on the MUTE output and the voltage cut off to remove off the semiconductor switch.
Sep 11, 2010 | Honda GL 1500 SE Gold Wing Motorcycles
Marantz pm 7200 lost sound, only works when volume is up high, still looks like there are no high or medium frequencies.
You have either lost the pre-amp stage or the Main Amp stage. Since you have a problem on both channels it most be a part that is common to both channels. Something like an IC I would suspect.
Oct 31, 2009 | Marantz PM7200 2-Channel Amplifier
47 people viewed this question
 Grubhead
Grubhead
