Question about Bertazzoni Griddle Plate SG36-X Stainless Steel
Major problems with Bertazzoni Griddle Plate SG36-X Stainless Steel
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
Fix scratches on stainless steel appliance
The professionals in order to remove the scratches from st. steel they use special metal wire meshes like soft scotch bride attached on special rotary milling machine. They brush it in the direction of the grooves on the st. steel surface. They start with a hard brush and they reduce the strength until they finalise it as the original finish. If it a brush surface this is more easy than a polished mirror surface. These procedure need experience and care so you will not end up with more damage than the original one.
Dec 29, 2012 | Electrolux 30" Electric Hybrid...
Some of the burners are not getting hot can you help
hi ok first step is to remove the top plate so that you can get at the burners you would need to be able to use a multi meter and check each burner that you are getting power to each one if you dont have power going to the burner then it would be a wire or control problem if you do have power then you have a burner problem hope this helps plz if you are not electronicly inclined call a technician
Jun 27, 2010 | Thermador CIT365EM Stainless Steel...
How to remove brown scorch mark on stainless steel cooktop cover
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Mar 26, 2010 | Jenn-Air JGC8536 Gas Cooktop
I have discoloration on my kitchen aid stainless steel oven top on the strip of stainless just above the controls. I have tried vinegar, baking soda and dishwashing liquid, oven cleaner(not heavy duty Easy...
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff really works!!
Aug 22, 2009 | KitchenAid Cooktops
Bleach stains on stainless steel triming on cooktop
DeBruce Polish is perfect in the RESTORATION of STAINLESS STEEL, it will even remove rust from stainless and polished chrome.
Check them out- you will be glad you did!
debrucepolish.com
Note: see DeBruce Method on "You Tube"brucedebruce09
Apr 01, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Stainless Steel Cooktop - Remove Sealant Spray
try paint thinners , but before you do any thing you need to call the workman to see what brand of glue he has used.or to come out and clean it off for you or to see if thinners will work , it normally does but when i do resturant kichens out any spillages of glue is removed straight away.you will need to use polish cleaner after the thinners to stop any further marks appearing
Feb 17, 2009 | Thermador PC366BS Stainless Steel Gas...
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Bertazzoni Griddle Plate SG36-X Stainless Steel Logo
Top Bertazzoni Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Bertazzoni Cooktop Expert? Answer questions, earn points and help others
