Question about Panasonic Toughbook Cf-53aagky1m Notebook CF53AAGKY1M
Bios password toughbook cf-53
Panasonic toughbook cf53 windows7 corei5 2520M Intel (R) core(TM) cpu@ 2,50 MHZ maderboard Panasonic corp. mod.CF53-1 BIOS A.M.I.Version V1.00L14 Data 07\12\2011
leecom72
  • 4806 Answers
SOURCE: Panasonic c-29 toughbook BIOS Password breaking
you have to remove or unplug the cmos battery which is attached to the motherboard inside the laptop, doing this will clear all passwords. If the password clears replace the battery.
Here is some more usefull info if you want to this yourself>
The guts of the machine are usually under the keyboard. If you are okaywith opening up the laptop, you'll need to remove a few screws, thebattery and the hard drive, then carefully pry up the keyboard to gainaccess to the items that the manufacturers say you shouldn't tamperwith. If its just a matter of getting into the bios and theres apassword, you can usually simply remove the battery and leave itwithout power for at least 24hours, then it should reset....doesn'talways work but since most laptops actually do not have a standard cmosbattery, this would be one way to go about it. Of course you could justtry to figure out what the password is, someone has to have put it inthere so they should know what it is, or you could go to http://tcc.toughbook.com/ and get the bios update, which will reset it completely.
Posted on Nov 15, 2008
asthanarht
  • 258 Answers
SOURCE: on boot up a safeboot apears and asks for password
if you are able to open motherboard then simply remove CMOS bettry for 10 sec and put again then password will reset...if you dont open motherboard then ask me?????
Posted on Apr 03, 2009
Tech_Mania
  • 239 Answers
SOURCE: BIOS password
Its in the motherboard.... remove the c-mos battery and then place it again...it will reset the bios password..
Posted on Jun 12, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
  • 222 Answers
SOURCE: i have panasonic toughbook laptop cf-73 and i
RESET BIOS JUST REMOVE BATTERY AND DISCONNECT FROM POWER .. ALSO DISCONECT BIOS BATTERY TO RESET BIOS , AND BIOS PASWORD
Posted on Nov 25, 2010
How to replace the hard drive for Panasonic Toughbook CF-S9 ?
Easy turn off all the screws from the pc and then change the hard disk drive and try install again the system new coment please !
Apr 10, 2014 | Panasonic Toughbook S9 CF-S9KWAZZ1M...
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Im using Toughbook CF53 and all of a sudden it is not working. I checked all the properties thru control panel and Fn + F4 keys everything looks fine. What could be the problem and can i get help how
    I had a similar situation with my CF-53. Oddly, the speakers would not work, but headphones plugged into the port on the front of the laptop would. Could you verify that you get audio through the headphone port, please?
    Dec 12, 2013 | Panasonic Toughbook CF-51 Notebook
    Clear / reset BIOS password on a Panasonic Toughbook CF-53
    You can usually reset the BIOS password by unplugging the CMOS battery and all other power sources.
    Then turn the computer on with power plugged in (not the CMOS battery though).
    After computer has booted up, turn off again, plug CMOS battery back in and password should have reset.
    Tutorial on how to do this can be found under soloution 2 of this link:
    http://www.wikihow.com/Clear-BIOS-Password
    Nov 28, 2013 | Computers & Internet
    Panasonic cf-53 no sound
    me also having the same problem.. no audio from my toughbook cf-53. it was working fine and dont know all of a sudden how it stopped working. how to fix it???? all Fn + F4 and other things from control did. but nothing seems to be working. please help me to fix it.
    Aug 16, 2013 | Panasonic Cf53 Panason
    Panasonic toughbook..cf-53 bios password to remove
    I have a CF-53. While I was in the BIOS, I had loaded the default BIOS settings. After rebooting, I realized my BIOS was now password protected!! WTH?? I called Panasonic Tech Support at 800-527-8675. The tech was VERY knowledgable, and when I explained the situation to him, he said that didn't seem normal and that Panasonic doesn't normally password protect the BIOS. On what seemed purely like a hunch, he suggested typing in "password" - Voila! It worked!!
    Thanks Panasonic Dude!!!
    Jan 05, 2013 | Computers & Internet
    CF-T7 bios password
    I was remove the cmos battry but same password pleas how can i remove the bios password of panasonic cf-t7
    Oct 05, 2012 | Panasonic Toughbook Cf-t7 Laptop Computer...
    I have panasonic toughbook laptop cf-73 and i forget bios password now what i do?
    Nov 25, 2010 | Panasonic Toughbook CF-73 Notebook
    Bios password for panasonic toughbook cf 71
    just clear the bios, by removing the jumper and put in its place again
    Sep 29, 2009 | Intel Motherboard
    Cf-28 superuser password
    goto bios setting see thast the password is there if yes then open the cpu and cleaar the jumoer setting and remove tha the cmos battery n plug it that will solve th e problem
    Jun 19, 2009 | Panasonic Toughbook 29 Touch (P/N...
    Panasonic Toughbook Cf-53aagky1m Notebook CF53AAGKY1M Logo
    476 people viewed this question
    Top Panasonic Computers & Internet Experts
    Oloyede Monsuru
    micky dee
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
