Question about Gateway Media Center 610XL PC Desktop
Non system message
My gateway 610 keeps giving me this message "non system disk --- insert boot disk and press any key "
  • 565 Answers
If you have a floppy drive, make sure there are no disks inside it. Same for cd or dvd drive. Also, check your BIOS (usually by hitting the F2 or Del key when first booting) to see if it recognizes your hard drive.
Posted on Jan 26, 2009
Need a new hard drive but have no windows vista disk
You don't.
Do you have backup software? If so, do a "disk and partition" backup. This essentially creates an image of your system, even if you have multiple hard disks. Decent backup software (I won't mention any brands except the one I use: Acronis) will allow for a boot time recovery of your entire system, either by inserting a post-bios command -- which will appear on your screen before windows startup with a message like "Press F12 for system recovery", or you should press whatever key your system allows for boot order and boot from the recovery disk you can create from the software.
You can even now immediately create a Windows backup to an appropriately sized USB mounted disk (even the terabyte ones are relatively cheap) and a Windows Recovery Disk...the recovery disk should be inserted and use boot order F-key...good luck
Dec 28, 2013 | Gateway DX4200-09 PC Desktop
How to restore factory settings on a dell inspiron 230 using disk
if you want to reinstall OS:
Insert the disk, it should automatically open the install.exe thing and you'll need to follow the instructions.
if you want to restore the computer to factory settings and reinstall OS:
turn off your PC
keep pressing the key for boot menu it's F8 or F12 or F11 depending on the PC's manufacturer.
Then there will be either a boot menu or a "Do you want to do a system restore":
a) system restore, keep pressing the key and it will load. Then follow the instructions
b) if it's boot menu, insert the disk, and then select the option which says to load from the CD/DVD. Then follow the instructions.
NOTE - PLEASE BE CAREFUL, IF MAKE ANY MISTAKE, COMPUTER MAY NOT RECOVER.
Jan 17, 2013 | Dell Inspiron 530 Desktop Computer
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Feb 19, 2011 | Microsoft Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Gateway mx6453 wont boot up- oper system not found
Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
if you get msg opperating system not found use the system restore disk
Hope This Helps good luck
Please leave feedback
Nov 26, 2009 | Gateway MX6453 Notebook
Computer began to intermittentally give error message quit workin
A noisy hard drive is never a good sign. It sounds as if the drive is failing or has failed. You didn't say what operating system you have, but let's try....
You can try the following but it may not yield much. If, after these steps, the PC does start up, try to copy as much critical information as you can to either CDs, DVDs, flash drives or whatever you have.
Start the PC
During the boot, you should see a message to press the F2 key to enter setup - press the key when you see this. You key might be different, but press the one it says to press.
When you get into setup, find and change the boot sequence so that your CD-Rom looks first for an operating system
Insert your backup operating system disk - I hope you have that.
If you are not comfortable working with your PC at this level, it's usually best to take it to a repair shop. The advantage here is that even if they can't get the PC to run, many shops can still recover at least part of your data unless the drive is really destroyed.
The disadvantage is the cost - which can vary widely.
Now see the directions below:
Running Recovery Console without installing it If you cannot start your computer, you can run the Recovery Console from the Microsoft Windows XP/2000 startup disks or the Windows XP/2000 CD-ROM.
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, use the following steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  3. When you're prompted to press F6 for mass storage devices - press F10 instead. This will automatically start the Recovery Console.
  4. Alternatively, when the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, choose the installation that you need to access from the Recovery Console.
  6. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  7. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
Apr 05, 2009 | Gateway Profile 4 All In One (MPN...
I have an old Gateway Solo 1450 laptop that I have upgraded the RAM and now need to do a BIOS update. (I keep getting error messages and IE closes after a while.)The installation instructions(from Gateway...
what you need to do is make a bootdisk. first go to start/ all program/accesories/command prompt
type format a: /s and follow the commands onscreen and then make sure you have that other fileon your loppy and boot from that.
Dec 03, 2008 | Gateway Computers & Internet
Reinstalling Windows
Make sure you start with the OS disk. Restart your computer with that disk in and then boot from that disk. If your computer doesnt auto boot from the disk go into the bios and set the boot order to cd first. Then follow the on screen instructions. Onces your done installing windows you can use the application and driver cd to install all the drivers.
Jan 22, 2008 | Gateway M305CRV Notebook
System recovery
It sounds like the boot sector on your main hard drive is corrupted. You should have created an emergency boot disk when you first purchased the computer. Since you don't have the oroginals you should borrow a system CD from a friend and boot up that way and try to a recovery. Selecting F8 during the bootup sequence allows one to start if Safe mode, but I believe (I usually run Linux) you still need the boot sector on the main hard drive to be valid in order for this to work. The F1 gets you to the Bios screen (?) where you can select the boot sequence (hard drive, CD, or floppy first/second/third), among other things. Hopefully someone with more Windows experience than I can assistance better than I can, I just thought I'd throw that out there.
Dec 05, 2006 | Gateway E-2000 Deluxe PC Desktop
Gateway Media Center 610XL PC Desktop Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
