Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Flood switch activated on dishwasher DW60CSWI
Flood switch activated - first 4 lights conitnually beeping, have switched off for 3 days and still doing it. All spray arms and filter are clean and clear
  • Fisher and P... Master
  • 3,247 Answers
Please clarify the model number. i am assuming you have a standard height single door dishwasher. It is likely the flood switch assembly itself is faulty and giving false results. Check the base of the dishwasher - item 95 in on page 10 in this manual. The microswitch could be faulty or the spring might be stuck.
Posted on Jan 21, 2013
  • 15 Answers
SOURCE: The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Posted on May 01, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Dishwasher beeps constantly and gives fault code
Hello there:
here is some ideas that will help you clean off the flood switch thatis causing the error
first unplug the power going to the machine
If you by accident overloaded the top drawer and this will allow water to get into the base an trigger the flood switch. which causes the error that you get .
Take the bottom drawer cover off first then took the whole drawer out and gently manuevere it to where u can get into the bottom of the unit.
use a towel and dry up any visible water.
use few paper towels to get into and under tight spaces.
now Take a blow dryer and blow the in the base for about 10 minutes. once there is No visible signs of water any where
put it back together and it should work . ok
Hope this is very helpful for you
Best regards MIchael
Posted on Dec 26, 2009
  • 3247 Answers
SOURCE: The flood switch has been activated on our Fisher
Turn off the main power to the dishwasher.
I am assuming you are getting F1 error code flashing (if your drawers have LCD display) or the LEDs are flashing if you have intergrated drawers.
The flood switch is located at the base of the drawer tub. You will have to either extend the drawers out fully or take them out depending on the amount of water that would have collected at the base of the tubs. Get some towels and dry the base out. You may also need a hair dryer.
Once the flood switch dries off the drawer should work ok when you turn back the power.
The causes of the flood switch trriggering is either too much foam in detergent (use recommended detergent) or leak in water in or drain pipe.
Please remember to rate the solution if it helps or post a comment if not.
Posted on Jun 12, 2010
  • 3247 Answers
SOURCE: Fisher Paykel Dish Drawer flood alert switch
Switch the main power off and on after a short time. If the error does not go away then you have water collection in the base of the dishwasher under the drawer.
Take the bottom drawer out and try to use a couple of towels to dry out the base plus use a hair dryer. (make sure the power is turned off at the mains switch). This should dry out the flood switch.
Now about the reason for water collection - could be kink in drain hose, water leak from drawer seal, foaming due to incorrect detergent.
You have not mentioned if the error is occuring in both drawers or just one.
Posted on Jul 14, 2010
  • 3247 Answers
SOURCE: Flood switch activated, intermittent beeping,
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Posted on Nov 28, 2010
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Danby DDW497W Dishwasher pump not working
It could be 3-4 things that are causing this issue,first: something got in pump and jammed it,second:pump is not getting power,remove back plate and check wire plug to pump,push it all way in and see what happens,check flood switch it could be defective and is not activating when unit is turned on,check wire plug to flood switch and make sure is all way in,if pump is not humming or do nothing or no sounds at all,than drain pump is bad or not getting current (power)drain pump should run as soon as you turn on unit,you must check Flood Switch,is on drip pan at the middle,it has styrophone in it,be careful or you can get the shock of your life.Good luck.
Jan 14, 2013 | Asko D1776 Built-in Dishwasher
Fagor LF 65IT beeps 4 times a few minutes after switching on and all lights flashing on display
This is a flood warning. You must have water in the bottom of your machine which has raised the float and activated the flood switch. Open the lower front panel on your machine and for where the leak is coming from.
Apr 03, 2012 | Fagor LFA-65 IT Dishwasher
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
Please help I have a aquarius FDW60 . The problem
It is likely the flood switch at base of dishwasher has activated due to a leak.
You will have to dry the leak and then try again.
Make sure the mains power is shut when you are working on the dishwasher to avoid electrocution.
Mar 16, 2011 | Hotpoint Dishwashers
Flood switch activated, intermittent beeping, motor will not turn off
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Jan 18, 2010 | Dishwashers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
333 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
