Question about Breville BKC600XL Coffee Maker
Machine is 1 yr old....all at once....will not stay on cup size..
Will not stay on cup size, leaking from somewhere on bottom....not heating correctly.....water comes out slow slow slow......I have descaled twice....intermittantly  'descale' appears......
Any Hope?
  • J. Barnts Jan 28, 2009
    Pump could be plugged, although I have descaled w/vinegar 3 times. Are you suggesting I take the machine apart and clean the pump?
    President:
  • 1,952 Answers
With the resevoir in place lifted it up about 2cm and 'dropped' it about 8 times. Each time, air bubbles came up from the bottom. After doing this, the next time that I went through heating, ready to brew, brew process, it worked fine.
Posted on Jan 28, 2009
  • mohammed marika thambi
    mohammed marika thambi Jan 28, 2009
    Check to see if hose in reservoir is disconnected, if so reconnect. Reservoir may be damaged.
    this is a fixed amount of coffee that can be used to make your cup of coffee regardless of size adjustale cup size and different strenghts.
    You have a timer you can pre-set in the morning so the
    water is already heated when you get up and the machine can also be
    shutdown automatically when you go to sleep or whenever you choose.
    Also, the machine is very easy to clean
  • 11,896 Answers
Take the machine a part, see if there is any wires broken or any parts on the system board that have broken. Something most likely shorted out and it is garbage.
    Brigadier General:
  • 8,619 Answers
Hi!
Cleaning the My K-Cup® accessory
Regular cleaning of the My K-Cup® accessory is
recommended.
1. Remove the assembled My K-Cup® Holder from
the Brewer by raising the Safety Locking Arm. Use
22 caution as the My K-Cup® Holder will be hot.
2. Disassemble the My K-Cup® Holder by removing
the Lid from the Holder in a counter-clockwise
direction. Remove the Filter Basket from the
Holder, discard the grounds.
3. Wash the Lid, Filter Basket and Holder in warm
soapy water with a soft cloth, then rinse and dry
thoroughly. All parts K-Cup® Holder are also topshelf
dishwasher safe.
4. Store the assembled My K-Cup® Holder in the
My K-Cup® Storage compartment located on top
of the Brewer.
Posted on Jan 26, 2009
  • Rylee Smith
    Rylee Smith Jan 26, 2009
    You Brewer is equipped with sensors to detect when scale buildup is interfering with the performance of the Brewer. When this is detected, the LCD screen
    will indicate ’DESCALE’.
    I think you haven't descaled it properly and it needs to be cleaned or if you have descaled it properly then your sensors are gone bad and are thus causing this trouble. Change the sensors or check for their connections.
    Thanks
    Rylee
    Sergeant:
  • 221 Answers
That being said, people who are thinking of buying this unit have to know that the same filters that produce the great crema they love will get clogged after 2 or three uses, and cleaning them will require a lot of work (unclogging the tiny holes with a pin, soaking the filters overnight in vinegar and/or running a lot of pressurizedboiling water through the empty filter), wasting a lot of unused coffee, and worst of all...wasting a lot of time to do all this (which hardly anyone has these days). I guess this problem would be solved if the pump was strong enough to push through the clogged filter, but that is not the case. When the pressurized water builds up, instead of going through the filter and coffee, it will go backwards and down to the reservoir in the bottom of the machine (picture trying fo inflate a balloon with a hole in it.) wasting tons of water in the process. Also, do not think that you can clean the filter after each use.....you cannot, because as I said earlier, the filter has two walls, the first one with a lot of tiny holes and the second one with a very small one. Whatever gets trapped within the two walls will likely stay, clogging the tiny holes and rendering the machine useless. Nothing will come out of the machine even with an empty filter
  • 130 Answers
Check your water source. Is it direct feed? slow water usually show some kind of blockage in the lines somewhere.
    Sergeant:
  • 378 Answers
Need to remove the pump as some thing is blocking the object.its common in this maxchines.just needs to be cleaned.
I was given a maxi-matic 1 cup coffeemaker but wont stay on long enough to brew a cup of coffee?
sounds like the heating element is bad or loose wire inside there only 20 bucks try buying a new one if you like fixing things take the bottom off check wires the cirkit on the heating element is bad or loose inspect it somtimes by replacing the element by removing it with a sodering gun and matching it at a radio shack or take one out of an old coffee pot...
Apr 14, 2011 | Maximatic EHC-100 1-Cup Coffee Maker
Our 7 year old Saeco Magic Delux has started to leak water when we fill the tank. It runs out of the bottom of the tank and down the side. Happens about 20% of the time. Is it worth having a 7 year old one...
If I understand well the problem is only with tanks valve which means the spring have become more soft and stays a litle open so you have water leak. It maybe because some scale or dirt keep it open some time.
In order to decide if it wise to fix it or not the answer is simple if you have a good coffee result in cup which means that the grinder grinds good, presure pump work good and boiler heat up ok then you will only need to complete descale the machine and replace only small cheap parts and you will have a very good machine again for some more years. Remember a brand new machine will do the same espresso like yours.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Magic De Luxe Espresso Machine
Water doesn't enter ice maker tray
You probaby just have an air lock somewhere. Trace the tube to where it taps into the water pipe. Remove the hose and blow thru it.
Feb 11, 2010 | Kenmore Refrigerators
I have a 3 yr. old toro, It wont stay running.
You probably have a crack or hole in the primer bulb. Replace it and see if that solves your problem.
Sep 20, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
I have a coffee pot per say it has the resivor and dispences one cup at a time. only 1 yr old but it doesnt seam to be geting any electricy so it dont work
Most likely a thermal resistor in the heater cicuit has blown, if you replace it youself make sure you install it in the right direction and do not to solder it in, the wires are crimped so not to damage the resistor with the heat from soldering.
Aug 02, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Recipes Are wrong in instruction booklet
I had a similar problem when I switched machines. It seems that most recipes will work in same size machines (1 or 1.5 lb loaf size). My issue was that my old machine had to have liquids in first and then dry ingredients (new machine is the opposite). I ruined several loaves before I figured out the issue. I would have never imagined the order of ingredients would make a big difference.
Oct 16, 2008 | Black & Decker B2250 Bread Machine
Leaking
I think there are a tube that is leaking in your machine, try to open the backplane of the machine.
/Mirran
Sep 22, 2008 | Gaggia Platinum Vogue 90800 Espresso...
Water not being forced through the cup
I've seen a few coffeemakers that have a gravity valve on the inlet side of the brew chamber. If this valve has become stuck open, then the hot water may be perking back into the reservoir instead of out to the coffee.
Feb 20, 2008 | Keurig B50 Coffee Maker
Breville BKC600XL Coffee Maker Logo
136 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Iron
Iron
Avishek Samaddar
Avishek Samaddar
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
