Question about Hoover Washing Machines
Wash cycle,spin dry, water level
Machine wont wash on any cycle or spin dry, and keeps filling overflowing drum,but all other funtions work properly
  • 65 Answers
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Posted on Jan 27, 2009
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Mar 23, 2015 | Maytag Washing Machines
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
My washing machine wont stop filling up with
well the part that tells the water to stop running in is the pressure switch if the water valve is working properly so disconnect the power and if the water continues to run in it is the water valve just replace it
Apr 26, 2010 | Washing Machines
Washer over flows with water and does not go into spin cycle
water level sensor is not working properly
with your solenoids to shut off water
Jun 02, 2009 | Washing Machines
Frigidaire fwx833as2 getting water on floor in wash cycle
Actually there are three fairly common causes for this:
The machine may not be properly leveled, and will go out of balance when spinning, no matter how carefully you load it. The drum tilts to one side and sloshes over the gasket at the top.
The pump might be blocked up badly, causing the water to not drain adequately, which can cause the water to be forced upward and out due to the building centrifugal force. These machines are designed to drain as they spin at a fairly steady rate. If something interferes with the draining, but doesn't slow the spin down, this can result.
Finally, the maximum water level switch (sometimes also called an overflow prevention switch, among other names depending on manufacturer) may be faulty. Normally your water level is controlled by the load size selector. However, on some machines the maximum load size setting is actually limited only by the overflow prevention switch. If yours is one of those, this could explain your problem.
Feb 07, 2009 | Frigidaire Washing Machines
My washer fills until it overflows...when I turn the dail to the wash cycle, it just drains and spins...
Most likely the water level switch broke or water level hose came loose, if the washer keeps on filling on after you turned it off, then is the water valve. Which brand is it?
Jan 20, 2009 | Washing Machines
Water Level control
if the pressure switch hose is not obstructed, check to see what happens if you try to **** thriugh the hose like a drinking straw
if you can and the pressure switch is wired correctly replace the pressure switch again
Jun 10, 2008 | Washing Machines
Washing Machines Logo
160 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
