Question about Speed Queen Washing Machines
My speed queen washer lws17nw cabinet top is rusting and needs replacement. Is a replacement readily available?
Replacement cabinet top needed
  • 177 Answers
SOURCE: Speed queen top loader
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
T
Posted on Jul 29, 2008
  • 1294 Answers
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Posted on Mar 06, 2009
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Posted on Jan 13, 2010
Model #AWM392W when water is filling tub, water is coming out from around the bottom
the outer tub seal is bad,you need to remove the inner tub then outer tub to replace this seal
Aug 07, 2011 | Speed Queen AWS52NW Top Load Washer
Do I put silicon grease on Speed Queen brake pads
Yes. In fact, the complete brake assembly replacement kit is supplied with some high-temperature silicon grease for exactly this purpose. I hope this helps somebody more than the other two posters, who are complete nobs.
Aug 03, 2011 | Speed Queen AWS52NW Top Load Washer
Speed queen washer mod.AWM 593W How do youu lift the top of the cabinet to remove inner basket?
use a 5/16" nutdriver/socket and remove the two screws and the bottom of front panel and tilt panel out and then look and find 2 screws(one on each side) facing up on the corners of top/cabinet, remove those and raise top
Jul 22, 2011 | Speed Queen Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
Speed queen washing machine mod kaw693 repair manual reqired
do you know where I can obtain a repair manual for my Kleenmaid KAW693 I need to replace the seals and bearings as it leaks a bit of water and makes a screeching noice when agitating. My email address is kerryn12@optusnet.com.au Thank you
Apr 28, 2009 | Speed Queen AWS52NW Top Load Washer
T
Jul 27, 2008 | Speed Queen AWS44NW Top Load Washer
Speed Queen HD comercial washer
Its sounds like you need a replacement knob, if you can turn the disc behind it to start a cycle and the machine times out find the timer is probably still good, do a Google search for Speed Queen parts, and buy the correct replacement knob.
Mar 30, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
