How do I adjust the flow rate of the cistern filling water. The valve on the wall is already right open. It is a Dux cistern with 2 plastic buttons. Don't know the model number either.
  • Washing Mach... Master
  • 17,129 Answers
If the valves cannot be controlled then it is either an open or close type. Try controlling with the valve on the outside.
Posted on Jan 21, 2013
  • 76 Answers
SOURCE: Maytag washer PAV2300 water over flow
tidalwave If the water continues to flow even when the washer timer and the power to the washer are off then you are right and the water inlet valve has to be replaced. If it does it only when the washer is on then it could be different problems. In that case the first thing you have to check is the water level switch. This is the device which controls the water level. Remove the power first.Open the control panel and you will see the switch on the left side. There is the clear plastic hose connected to the switch. Make sure the hose is not loose. This is one of the most common cause of overflow. If it got loose, drain out all water from the washer before you reconnect the hose. If this is not the issue then you have to check the continuity across the water level switch therminals. When there is no water you should measure the continuity across therminals 11 and 12 (gray and orange wires). Whet the tub has filled up with water you should measure the continuity across therminals 11 and 14 (gray and light blue wires). If the continuity is wrong replace the water level switch. If you are going to do it, make sure there is no water in the tub before you will remove the clear plastic hose from the old switch. Good luck. Gendos. post back...
Posted on Jul 08, 2007
Healeyman
  • 1198 Answers
SOURCE: Whirlpool model LSR7233EZO / doesn't fill fully
The fill switch is a very sensitive device. You can test it by blowing into the tube, listen for the switch to click, or use an ohms tester. They are actually adjustble, the adjuster screw usually has glyptol (thread lock) on it. I would replace one before trusting an adjusted one.
Posted on Jul 29, 2008
  • 27 Answers
SOURCE: Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
beltronic205
  • 1461 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
ginko
  • 19396 Answers
SOURCE: Maytag Atlantis Model Number MAV9501EWW
Hi.
Test and eventually replace the inlet valve.
The inlet valve is tested reading impedance, if it is broken, then it usually read infinity (circuit open). Reaing is done disconnecting valve and pointing multimeter probes at valve solenoid contacts (the cold ones in your case).
A definitive test on inlet valve is done reading volts while cycling and observing if valve is opening. For safety reasons is better if the user performs only tests that can be done with power off.
The switching contacts and inlets is also a test even if basic, I think that the valve is gone.
Here part:
Series 21 models: sub 22004333 (water inlet valve)
Series 12 models:VALVE-INLET
Valve is part nr.2 in diagram below. Click on the picture to enlarge.
If you repute this solution helpful, then please do not forget to accept.
Best regards.
Ginko.
Posted on Oct 01, 2010
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
Can low water pressure cause my toilet cisterns to keep running
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
Nov 16, 2016 | Home
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
Dux toilet cistern problemsolving
can only be one of 2 things. the inlet valve is not shutting off properly and so the tank is overflowing into the toilet bowl or the flush valve rubber is worn out. you can find this at the bottom of the flush valve mechanisum.
Dec 04, 2013 | Home
Adjust water level in in-wall Italian toilet cistern
It could be your flushing mechanism inside the tank that is letting the water in even after the flush. First flush and watch the bottom mechanism whether it blocks completely when water is full in the tank at set level and no more water flows.
Jul 27, 2013 | Home
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Even after filling up, water from the cistern keep...
That is the cistern overflow running.You need to adjust the fill level in the cistern by adjusting the plastic screw on the ballfloat or adjust the height of the float if its the silent fill tpe
May 20, 2010 | Home
Toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Apr 21, 2009 | Kallista Michael S Smith Country Elongated...
When tap or cistern is filling loud noise from pipes
This could be one of two issues.
1. You may have high water pressure, causing the internals of the fill valve to vibrate and that vibration wave being transferred to your water pipes causing a reverberation noise called hammering.
An easy fix for this would be to reduce the flow to the fill assy. by turning down the units supply valve from wide open to about half way open. A few more permanent solutions may include, The installation of a Water hammer damper device - installation of a PRV pressure reducing valve - Although not intended for this issue is an air charged bladder style expansion tank installed, this device has been proven to reduce water hammering.
2. Water pipes that are not properly secured, loose and allowed to shake when there is a sudden surge of flow pressure. Much like a garden hose flexes when the nozzle is quickly turned on. This issue is most common with CPVC (plastic) water lines due to their flexibility and will require many more secure points.
A fix for this is a bit more labor intensive, due to having to access the un-exposed water lines in walls and ceilings so as to inspect and/or re-secure them to their surrounding structures.
A tip for securing the pipes where they penetrate through wall studs is to inject an expanding foam product in to the studs penetration, hence when the foam expands and cures it will form a very snug fit.
Note: if ether of these are the case, the problem should not be allowed to continue, because water pipe leaks could occur at the solder or welded connections and/or at locations where the pipes are rubbing against an abrasive surfaces causing a rupture.
Good luck
Aduz
Mar 27, 2009 | Caroma 270W-RF Reflection Round Front...
Problem overflow valve
Firstly open the top of the Cistern(Where water is held)There are two most common Cistern internals ie;Ball-O-Stop(Ball on a arm connecting to valve). This one is easy, you just bend the arm downwards in the centre so that the ball shuts the valve at a lower level; The other type has a shaft(plastic) with a thread on it, connecting it to a "small bowl" that lifts up as water enters the cistern. To adjust the water level in cistern you have to turn the thread(Shaft) lowering the "small bowl" wich will shut the inlet to the cistern at a lower level. Hope this helps
Mar 04, 2009 | Caroma CARAVELLE270ADAW-EL Caravelle...
Washing Machines Logo
351 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
