Question about Ingersoll Rand Air Tools & Compressors
What is a 5 CPT fail? - Ingersoll Rand Air Tools & Compressors
Hp 30b cpt button
The CPT button is a feature of TI calculators. HP calculators don't need it. To compute a result, simply press the appropriate button without making any data entry.
For example, to compute PMT after entering n, i, PV, and FMT, simply press the PMT button, instead of pressing CPT then PMT as with a TI calculator.
Dec 16, 2012 | HP 30b Business Professional Calculator -
How do i Opened my cuisinart toaster cpt180
The Instruction Booklet for the Cuisinart CPT-180C Classic Metal 4-Slice Toaster can be found at the following link:
http://www.cuisinart.ca/pdf/ibs/en/CPT-180C_en.pdf
Not sure what you are trying to open. There is a slide out catch tray for cleaning crumbs. There is no information in the booklet that suggests a need or a way to open the toaster.
Perhpas reviewing the booklet will answer your question.
Jun 28, 2012 | Cuisinart CPT-180 Metal Classic 4-Slice...
How do I remove the button for browning control. My model is CPT-90C
wrapped a rubber band around it, attached vise grips, and pulled very hard.
Sep 05, 2011 | Cuisinart CPT-90 Classic Style 4-Slice...
Hi ,I am using HP10bll calculator and there is no CPT button ,I was wondering if there is any other buttons thta I can use instead of that one.Thank You.
You don't need one. Some other calculators require you to press the CPT button and then the button specifying what you want the calculator to compute (PV, PMT, etc). The HP knows whether you've just entered a number or not. If you haven't entered a number, simply pressing the key will compute the value. So for example, if the book says press CPT and then press PMT to calculate the payment, you just need to press PMT.
Aug 11, 2011 | HP 10bII Calculator
I would like some help in solving some TVM problems using the BA II Plus calculator. i.e. How to solve: I invested a lump sum of $2400 in an investment that returns 6% annually. How much will the...
2nd [CLR TVM] (clear TVM registers)
2 4 0 0 +/- PV ($2400 initial investment, negative because you're paying it out)
6 I/Y (6% annual interest)
1 N (one year)
CPT FV (compute future value, see 2544.00, the value after one year)
5 N (five years)
CPT FV (see 3211.74, the value after five years)
1 0 N (ten years)
CPT FV (see 4298.03, the value after ten years)
Feb 19, 2011 | Texas Instruments BA II PLUS Financial...
Cant find the cpt button
You don't need a cpt button on Hp 10ii calculator.You can just press the function button that you want to apply without pressing cpt first.
Jan 22, 2011 | HP 10bII Calculator
Cpt button
The Ti83Plus does not have a CPT button.You find that on Financial and Business calculators.
The Ti83Plus, does have a finance application. To access it press [APPS][1:Finance] and choose the program you want to use.
Mar 03, 2010 | Texas Instruments TI-83 Plus Calculator
Need help finding the CPT Button on the Sharp EL 738
CPT does stand for COMPUTE, on other calculators this is the COMP button, same thing, different name.
Mar 08, 2009 | Sharp EL-738 Scientific Calculator
CPT button on HP Calculator
Dec 17, 2008 | HP 10bII Calculator
Air Tools & Compressors Logo
160 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
