Question about GE GSL22JFXLB (22 cu ft) Side by Side Refrigerator
Tfx22 where is the drain pan
Drain
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
Bad transmission seal on a 2002 ford explorer
Drain the Transmission Fluid and Replace the Filter
Raise the car with ramps or a floor jack and support it with jack stands. Find the lower cover of the torque converter housing. Turn the torque converter until you find the drain plug. Place a drain pan beneath the drain hole, remove the plug and drain the fluid.
Remove the cooler lines at the transmission and flush them with compressed, low pressure air. Be careful during this step; fluid may shoot from the other cooler line.
Place a large drain pan beneath the transmission. Loosen the retaining bolts on the oil pan with a socket wrench until they are within a few turns of removal. If the seal doesn't break on its own, gently tap it with a rubber hammer. Fluid will drain from the edges of the pan.
Remove the pan retaining bolts when the fluid stops draining. There is still transmission fluid in the pan. Hold the pan carefully and drain as much as you can into the drain pan.
Scape the old gasket material from the mating surfaces on the oil pan and the transmission. Discard the old gasket. Clean the magnet in the pan. Clean the pan and the mating surfaces with a solvent and a clean, lint-free cloth. Replace the magnet and allow the pan to air dry.
Employ a socket wrench to remove the bolt that holds the filter onto the transmission. Some models may have two bolts. Pull the filter and any old seals or gaskets from the transmission. Install a new filter assembly, including any required seals or gaskets.
Put a new gasket on the oil pan and reinstall it on the transmission. Tighten the retaining bolts to 79- to 119-inch pounds with a torque wrench. Replace the cooler lines on the transmission and the drain plug on the torque converter.
OBD Tools 365 Days Shop
Sep 25, 2014 | 2002 Ford Explorer
How to drain and fill transmission fluid in 2012 chevy malibu?
GET NEW GASKET AND FILTER FOR TRANNY ALONG WITH THE FLUID (BEFORE YOU BEGINE)
GET A LARGE FLAT DRAIN PAN.
PUT CAR UP ON 4 JACK STANDS.
place drain pan under tranny pan.
undo tranny pan screws - allow one corner to hang lower than the other corner (to allow fluid to drain) slowly remove them all.
Its messy! empty tranny pan into drain pan. set tranny pan to the side. undo the filter clamp, carefully remove the filter - set into the drain pan, remove the gasket around the tranny body/tranny pan.
Clean tranny block surface with clean cloth. install new filter, install clamp tightly. Clean tranny pan, place gasket onto pan and then reinstall tranny pan. (this only change the fluid in the tranny body and pan) If you wan the fluid out of the torque convertor you have pull the pan under the torque convertor and turn the convertor so you can get at the drain plug. Allow fluid to drain into drain pan. Reinstall drain plug and pan. (you will need a lot of fluid) Check manual for qty. Place car back on to ground/floor. Refill tranny through filler tube. Do not start the engine until oil is at full mark, and when you do start it do not all it to run for than 4 minutes - stop and add more fluid and check full mark again (repeat until no longer sinks below full mark. gently test drive around you block -- come back and check level while engine running. Top up if needed.
Siphon out excess above full mark. Test drive around 3 block,
come back check full mark. Because the torque convertor was emptied it can take a while to get all the air out it.
Jul 19, 2014 | 2012 Chevrolet Malibu
Why the center bar betwen freezer and frige hot to the touch?
There are heaters to prevent the doors from freezing shut.
Jul 16, 2014 | GE Refrigerators
How to do a transmission fluid/filter change on a gmc 1500 2wd v8 350 step by step
Raise the vehicle. Refer to Vehicle Lifting. Place a drain pan under the transmission oil pan. Remove the oil pan drain plug. Remove the oil pan bolts. Remove the oil pan. Remove the gasket. Remove the magnet. Remove the oil filter. Remove the filter neck seal. The transmission oil pan gasket is reusable. Inspect the gasket and replace as needed. Clean the transmission case and the oil pan gasket surfaces with solvent. Install the filter neck seal. Install the oil filter. Install the oil pan gasket to the pan. Install the magnet into the bottom of the pan. Notice: Refer to Fastener Notice in Service Precautions. Install the oil pan to the transmission with seventeen bolts. Tighten the oil pan bolts to 11 Nm (97 inch lbs.) . Apply a small amount of sealant GM P/N 12346004 to the treads of the drain plug. Install the oil pan drain plug. Tighten the oil pan drain plug to 18 Nm (13 ft. lbs.) . Install Dextron Automatic Transmission Fluid. Lower the vehicle.
Jul 04, 2011 | GMC Sierra 1500 Cars & Trucks
How do i remove 2008 cobalt oil pan?
  1. Raise and support the vehicle.
  2. Place a drain pan under the oil pan drain plug.
  3. Remove the oil pan drain plug.
  4. Drain the engine oil.
  5. Remove the engine belt
  6. Remove the lower AC compressor bolt.Remove the 4 oil pan to transaxle bolts (1).
  7. Remove the oil pan bolts.
Jun 17, 2011 | Chevrolet Cobalt Cars & Trucks
I have an Amana AP148D, can I run it without an external drain hose? It says self evaporating, what does this mean?
Self evaporating simply means there is a drain pan with a heater device installed that will evaporate and condensate that drains from the unit into the pan.
You do not need the external drain pan unless the unit makes more water than the drain pan and drain pan heater can handle.
Jul 11, 2010 | Amana Heating & Cooling
Not sure i am locating the oil drain plug or the auto trans drain plug on my 2006 chevy silverado 1500. i am almost certain it is the oil drain plug but want to make absolute certain before i drain it....
Transmissions are drained by removing the pan itself. A new filter is to be installed upon draining. That is why there is no drain pan plug. The Chevy Powerglides were the last American made car with a drain plug in the 1965
Apr 24, 2010 | 2006 Chevrolet Silverado 1500 2WD
I have a split system SAP-K181AHA, SAP-K241AHA that is leaking water from unit inside house.
Air conditioners wring moisture from the surrounding air that collects in a pan under the cooling coil in the inside unit.
Chances are that the condensate drain is plugged or the drain pan is plugged. Look for a hose that exits the inside unit and runs to a drain. You can follow it back to the drain pan of the A/C unit. If there is water sitting in the pan, then either the hose or pan or both are plugged.
Turn the unit off, get a small bucket and remove the drain tube. Catch the water in the bucket. Blow through the drain line until it's clear. If the thought of doing this is too repulsive, then use an air compressor or even a manual tire pump. Now check the drain pan in the unit for debris and remove as much as possible from the pan and the drain fitting.
Both the pan and drain line should be checked at the beginning of each cooling season.
Reinstall the drain tube and see how it works!
Jan 07, 2010 | Sanyo Heating & Cooling
Water in box waqter keeps accumulating on shelves iveg bins andunder bins
When the freezer goes through the defrost cycle, the water collects in the defrost drain pan and drains into a pan underneath the unit where it evaporates over time. If the defrost drain pan is clogged, the water will fill the pan where it will freeze. Once the pan is full of ice, the water from the defrost cycle will run over the pan and down into the fresh food section. This will require that the drain pan be clean of the ice and the drain tube cleared of ice and debris.
Hope this helps.
Aug 07, 2009 | Whirlpool Refrigerators
GE GSL22JFXLB (22 cu ft) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
