Question about Braun Novamat 330 Slide Projector
Autofocus slides keep going in and out of focus. Can I adjust it?
    Scholar:
  • 33 Answers
Hi- I'm not at all familiar with this model so won't suggest a particular fix. However, in general, you may find some gear or other mechanical linkage, or perhaps a spring holding a gear in place has slipped. That caused the same symptm in some old Kodaks I know of. If you cannot figure it out AND you don't mind not having autofocus, you could disable AF. Inside you will find some sort of small light bulb. Disconnecting one lead will turn off that light and prevent AF from doing anything. If you end up taking that route, make sure you load all your slides in with the emulsion facing the same way (that's the less shiny side of the slide). This will reduce the amount of focus difference between slides.
Posted on Feb 20, 2009
It was a gift and i have no idea how to use it(AF 10 compact)
Oh, neat! Autofocus binoculars, they run off the same lithium batteries used in cameras (just like an autofocus camera, without the film). Minolta got out of the business in 2006, so unfortunately unable to find a manual, but this eBay listing (for a slightly less powerful unit) covers the basics pretty well.
Minolta Binoculars Autofocus 8X22 6 5 RARE WORKING eBay
From the listing:
Holding down the large button continuously focuses on the subject. The two smaller buttons are to focus manually. Minimum focus distance is about 6 feet. Eyepiece spacing adjustment is with the sliding bar that has a locking lever on the bottom side. Individual diopter adjustment is with the two sliding bars on the bottom, to match each eye to the autofocus.
Oct 21, 2017 | Optics
How do i turn off auto focus?
To strictly turn off the auto-focus, you have 2 options:
1. Some generations of 5600's have an Autofocus On/Off Switch. If so equipped, move the switch to "Off".
2. Remove the bottom cover. Locate the auto-focus motor and clip on of the wires that power the motor.
If repair is what you want to do, the problem becomes more complex and expensive! You will have to contact: www.micro-tools.com
You can order the 2 special tools, instructions and any other parts you need from them. When Kodak stopped supporting the slide projector business, micro tools bought out the remaining repair parts.
Feb 24, 2015 | Kodak Carousel 5600 Slide Projector
Why does autofocus keeps moving in and out on some slides
The autofocus system isn't really "autofocus". It is a measuring system - you manually focus the first slide, which sets the distance from the front of the slide in the gate to the back of the projection lens. By the focus motor moving the projection lens, subsequent slides will maintain that same distance. Continuous focus adjustment suggests that:
1> The curvature of the slide is changing because of the varying heat absorption rate of the transparency.
2> The autofocus system is out of calibration.
3> The autofocus system has a bind (it is being restricted from free operation).
About the only thing a user can do is to make sure ALL slides are oriented the same way in the tray. Beyond that, you will need a service manual and 2 or 3 specialized tools. Parts and tools can be purchased from: www.micro-tools.com
Good Luck !! jim
Jun 24, 2014 | Kodak Carousel 5600 Slide Projector
The manual focus ring on my camera doesn't work. The ring turns but does not seem to adjust the focus. Automated focusing still works. How to fix it?
Two methods:-
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
Jan 31, 2011 | Konica Minolta DiMAGE A2 Digital Camera
The autofocus will not focus. The paper is blurry. How can I fix it?
Remove the orange plastic parts near the camera.
There is a square opening/hole.
Get a long small screwdriver and adjust the screw connected to the lens.
I did this with it on, so I could see if it was making a difference. I am not 100% sure if adjusting the screw was the fix. However, moving stuff around in that area seemed to make a huge difference.
Sep 08, 2010 | Elmo Projectors EV-200 Slide Projector
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Autofocus off
Is this when you are trying to focus on something close up? If so you want to go into Portrait mode (turn dial to little head) then hit down arrow on the wheel once to MF mode (manual focus), then use the left and right arrow to focus specific inches or cm.
May 31, 2008 | Canon PowerShot A630 Digital Camera
LS5000 ED with slidefeeder sf 210
Hi there I had the same problem with auto focus sf-210.
If tried many things to correct the problem and what I found was that if you you put a small book halfway on the opposite site of the power button then I have maybe 1 or to slides out of focus and the other 35 slides are perfect ! (I used it with HAMA slides other slides I didn't test )
Hope this wil work also for you,
Paul
Dec 15, 2007 | Nikon COOLSCAN 5000 ED Film Scanner
Won't autofocus
First try another lens on the body and see if the problem is the lens or the body,if its the body the autofocus mirror could be out of adjustment, if its the lens, it sounds like the lens took an impact and needs a pro repair. you should be able to set body to manual focus and focus lens to infinty.
Jun 11, 2007 | Nikon D50 Digital Camera
Slide projector autofocus constantly adjusting
My slide has the remote but remote is not working the projector i have is v5000Af
Jan 02, 2007 | Vivitar V5000AF Slide Projector
Braun Novamat 330 Slide Projector Logo
247 people viewed this question
Top Braun Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
