Question about Refrigerators
Gallery LGHS2634KPO door codes
The codes on the front of the refrigerator and freezer are reading wrong
4 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
Posted on Jan 24, 2008
woodchuck789
  • 4059 Answers
SOURCE: Refrigerator doesn't work but the top freezer does.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 10, 2009
rickead1
  • 1998 Answers
SOURCE: samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Posted on Apr 29, 2010
How do I remove the front control panel from an Electrolux model GFFH17F8HBA freezer. The brand is Frigidaire Gallery.
Go to repairclinic.com. and input your refrigerator model. They have videos on how to do this type of thing.
Feb 13, 2015 | Frigidaire Refrigerators
Why does my freezer located on the top of the gallery refrigerator have frost in it?
Check the freezer door gasket! Frost build up along the front edge of the freezer indicates a poor or broken seal. It could also be packaging or plastic bags on top of the freezer getting into the door opening and allowing moist room air into the freezer--make sure nothing on top of the refrigerator is getting into the door or jamming it open.
Aug 21, 2014 | GE Refrigerators
How to put refrigerator into demo mode?
Hello friend, that's a great question!
In order to put your Frigidaire refrigerator FGHB2866PF into demo mode you would need to push and hold the "up arrow" on your freezer and the "down arrow" on your refrigerator for five seconds. Once your appliance has went into demo mode both the refrigerator and freezer display should read 77. Hope this information helps. -Matt
Jul 21, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Freezer ices up and fridge part warm, timer changed worked well for 2 weeks model frt 163ag no frost fridge
Hello Claire Trancoso - If the refrigeration side is the one with the issue, you need to check the damper door/switch that is between both doors. In side by side units this damper controls the cool air from the freezer to come over to the refrigeration side to cool it. Contact a professional technician to diagnose if the unit has a floating restriction, an issue with the evaporator fan or a possible air leak.
Dec 17, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Where is damper switch on my gallery series
The damper switch / door is between your two doors. It is the one part that allows cool air from the freezer to cool the refrigerator portion.
Jul 18, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
FRS2625H - frigidaire gallery professional freezer is maintaining temperature but refrigerator is not - barely cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Frigidaire FRS26H5AS Side by Side...
Fan in freezer not running
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Frigidaire Gallery GLHT184TJS Stainless...
I have a combined Bosch fridge/freezer unit. It is the frost free type of freezer. Lately, the bottom unit (the freezer), the door sometimes seems to have no pressure behind it and will not stay shut.
use a level to make sure unit is not tipping forward. adjust 2 front feet to tip slighly backward door will then close itself from about 6 inches......poss feet have sunk into floor covering.....
Feb 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
