Question about Prestige 2 Button Remote Security System with Shock Sensor and Starter Disa
Reprograming Audiovox Prestige 3 Button Remote Security
  • 13 Answers
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Posted on Dec 04, 2008
jpk528
  • 95 Answers
SOURCE: prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Posted on Feb 16, 2009
reynosaelect
  • 165 Answers
SOURCE: I don't know how to use my keyless remote start
DO YOU THE MODEL OF THE ALARM,PROBABLY NOT,EMAIL ME I THINK I CAN HELP YOU,I NEED TO KNOW HOW THE REMOTE TRANSMITER LOOKS LIKE.HERES MY EMAIL: reynosalectronics@live.com.mx
Posted on Mar 17, 2009
  • 11 Answers
SOURCE: Remote starter does not work after the battery
Turn key on and press valet button 3 times then press butoon on remote.Turn key of and thats it
Posted on Nov 16, 2009
  • 50 Answers
SOURCE: Reprogramming instruction for Audiovox Car
TURN KEY ON.
PRESS THE VALET SWITCH WITHIN 5 SECONDS,
3 TIMES.
HOLD THE GREEN BUTTON DOWN THEN TURN KEY OFF
Posted on Jan 22, 2010
Prestige APS787C wont start car
Try reprogramming the remotes: Turn ignition on, press and release programming/Valet button on antenna three times. You should here a short chirp, press the lock button on one remote. You should here a long chirp. Press the lock button on the other remote, you should here a long chirp. Turn ignition off. Test system.
Feb 11, 2013 | Prestige Remote Start
My door lock button starts car
You have to find the program overide button and reprogram the remote. First you turn on the ignition and then press the button 3 times you should have a confirmation chirp and then press the lock button 4 times ( if you have 2 remotes press it 2 times on one and 2 times on the other) then press the program button again and press the unlock 4 times( 2 and 2 if you have 2 remotes) and press the program button again and press the remote start button 4 times( 2 and 2 if you have 2 remotes) and do the same for the last button and you are all done.
Jan 08, 2011 | APS787 Prestige Remote Start and Security...
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
2002 Lincoln Towncar, Audiovox asp901, customer lost her keys and had new ones cut and reprogrammed. Now the remote start will not work. The pats light flashes and it wont start with the remote. I need to...
The PATS bypass module should have disconnected during the new key programming. First, you need two programmed keys present. Put the first key in the ignition, turn ignition on, wait for security light to go out. Remove key, immediately put second key in the ignition and turn ignition on. Wait for the security light to go out, remote start vehicle with controller, immediately remove key. Let the vehicle start and run for approximately 10 seconds. Apply brake to shutdown, wait approximately 10 seconds. Remote start to test. If vehicle does not start, repeat process.
Sep 15, 2010 | Audiovox APS901 Car Prestige Remote Start
I have a prestige APS2K4SAW remote and it just quit working, how can I fix it please????
for a programming guide to reprogram it we offer it for free in our website's forum at www.lesscoelectronics.com if you need more help we also offer free live chat there as well. Good luck!
Jul 01, 2010 | Car APS25CH Prestige 2 Button Remote...
I need to know how to set up a key fob for Audiovox PRO-OE2C4S
TURN KEY ON
THEN PRESS VALET SWITCH 3 TIMES
THEN PRESS LOCK BUTTON.
TURN KEY OFF
Jan 04, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
Would you recomend the Audiovox Prestige APS901N for my '06 Chrysler T & C mini van?
IF RANGE IS NOT IMPORTANT I SUGGEST A AUDIOVOX AS9076N . ITS AN ADD ON REMOTE START WHERE YOU WOULD PRESS
LOCK
THEN UNLOCK
THEN LOCK AGAIN ON YOUR FACTORY REMOTE AND THIS WOULD START THE CAR.
I BELIEVE THE IGNITION KEY HAS BUILT IN KEYLESS ENTRY BUTTON ON IT ALREADY. SO WHY CARRY ANOTHER REMOTE?
MOST OF AUDIOVOX MIDRANGE SYSTEMS HAVE THIS OPTION FOR ADD ON REMOTE START SYSTEMS WHERE YOU CAN USE THERE REMOTE OR TIE IT IN WITH YOUR EXSISTING REMOTE.
OTHER UNITS WILL HAVE DOUBLE LOCK OPTION TO START CAR. OR TRIPLE LOCK OPERATION.
Dec 24, 2009 | Prestige Remote Start
Want to buy a prestige aps998 remote and cant find it
You have to contact Audiovox by web or phone to order the dot matrix remote. It cost $85 + shipping. I'm lookin for a way to order online myself.
Sep 24, 2009 | Prestige 2 Button Remote Security System...
Prestige platinum by audiovox need to replace the remote for it
Feb 15, 2009 | Prestige 2 Button Remote Security System...
Prestige 2 Button Remote Security System with Shock Sensor and Starter Disa Logo
14 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
