Question about RTO American Heat Tankless Electric Water Heater
How do reset the thermal saftey cutout switch
The thermal cutout, on the left side, pops up when water stops flowing through the unit. The modules are Polymer. I can press the button, have tons of hot water as long as the water is flowing through...
The left canister probably has a grounded element in it, which will keep power going after the water is off. Either that or you have a bad triac on your control unit
Nov 03, 2013 | Bosch PowerStar AE115 Tankless Water...
The thermal cutout pops on tank two after it shuts off. It boils then shuts off. It also turns off when taking a shower, producing cold water. I checked the ohm readings on the thermal cutout and the...
Question posted under Bosch tankless.
Question says 'tank'
Brand, model, and type heater unknown.
Elements mean electric.
'Thermal cutout pops when taking shower produces cold water' indicates tankless, since tank-type would maintain some hot water.
No error code might indicate tank-type.
Add a comment with type, brand and model number of heater for possible assistance.
Sep 24, 2012 | Bosch PowerStar AE125 AE125 Whole House...
I have a bosch mod. 45557701 tankless elect. water heater I need a new thermal cutout switch, and cann't find anyone who sells it. I have to reset all the time all day long it makes sounds like a air...
1) Call Bosch.
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
2) Save money and buy whole new tank-type
electric water heater at local box store for $250, and go on-line and get coupons before purchase.
http://waterheatertimer.org/pro-n-con-for-tankless-water-heater.html
Sep 15, 2011 | Bosch PowerStar AE125 AE125 Whole House...
I have a powerstar ae115 water heater that is 3 years old. The thermal cutout onthe left side keeps tripping. after shutting off the shower the temp on the top of the unit is reaching 185*f. I have...
You've done the required first-step troubleshooting and maintenance.
If thermal cutout keeps tripping, and unit is actually reaching 185, then something is wrong with wiring, temperature sensor, gas valve, or PC board. Or combination of factors.
Call service technician, and open following link for some Bosch tankless resources including Bosch contact information:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 26, 2011 | Bosch PowerStar AE115 Tankless Water...
Pilot wont light
If the pilot went out it could be hard to see the pilot. If you have a model that has a sight glass the pilot will be up and to the left. Knowing where to look may allow you to see the pilot easier.
Some models may have a white thermal reset switch which is located to the right opposite of the sight glass. If your model has this you will see it after removing the outer door. The thermal switch has two wires connected to it and in the middle has a small reset to push. After pushing the thermal switch you may relight the water heater.
If this does not work the manufacturer can offer technical support. Their number is 1-877-817-6750.
Sep 29, 2010 | Whirlpool Water Heaters
The Thermostat does not reset!!!
Hi jamaica,the reset pops on tank/water tempature. The unit is overheating or the reset/saftey has become defective.Recommend replace thermo.
Mar 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Tankless water heater overheats
If this is not a sealed combustion unit, service the water valve OR rebuild the water valve if it is over 5 years old.
Mar 11, 2010 | Bosch & Tankless LP Hot Water Heater
My heater stoped heating water. the light is out that shows temp.my husband is in Military and i am alone. I checked circut breaker but I don't know if or where there is a circuit breaker at the box or a...
I had the same problem with the Stiebel Eltron Tempura 24. Right side unit worked (with blinking LED), but the display and left side (including LED) did not work.
This is CRITICAL. Do not take the cover off unless you have turned off circuit breakers at the circuit breaker panel AND tested that there is no power. There is a lot of voltage/ampreage here and it could be life threatening if you get shocked. Call an electrician (or a plumber) if you don't know what you are doing.
My problem was solved by resetting the safety thermal cutout switch on top of the non working unit (red single press thermistor). See this manual http://www.stiebel-eltron-usa.com/pdf/install_tempra.pdf page 8.
Jan 30, 2009 | Stiebel Eltron TEMPRA 12 Tankless Water...
RTO American Heat Tankless Electric Water Heater Logo
32 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
