Question about Dell Inspiron 1018 Notebook
Laptop won't charge
Charger has been tested and works but does not charge laptop
    Novelist:
    Champion:
  • 233 Answers
It may be your laptop dc power jack is loose or dead. You should fix it. If you are good at tech, you can do it by yourself based on the following instructions:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Otherwise you need to take it to a tech center for examination. Hope this will help you
Posted on Jan 23, 2013
2 Suggested Answers
electrotech1
  • 1126 Answers
SOURCE: My laptop is not recognizing
The charger is defective, not putting out enough voltage to operate unit or charge the battery, unit needs replace, check with best buy.
Posted on Jun 07, 2011
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
To test the laptop:
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Laptop won't charge. Replaced battery and charger and still does not work.
Please check the connector / port where u plug-in the charger. Does it happen with all other compatible chargers or only with the one you have. Also try charging some other compatible laptop with the same charger. If that works, it means there is some problem with the port. Its not making the connections well.
Aug 12, 2012 | Toshiba Satellite L655-S5103 Laptop
Battery won't stay charged
Bring the power cord/charger to a pc shop and have them test it. It might need to be replaced. Otherwise you need to replace the battery.
Jul 21, 2012 | Acer Aspire 55155879 Laptop Charger...
Gateway W350i won't charge new battery
1) the charger from power supply inside of the laptop is defective.some component is burn or open,or short.
2) Of course you must shure that the batteries new is o.k you must go where do you buy and test it in another computer for to see is charging.
God bless you
May 09, 2012 | Gateway Computers & Internet
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
Dell Inspiron 1018 Notebook Logo
56 people viewed this question
Alun Cox
