Question about RCA TruFlat 27F520T 27" TV
I have the Hiense Tv model # TC24FS2H. My roomates hamster chewed through my power cord. How do i get it replaced and can i do it myself?
  • 3 Answers
Well technically, some copper wire and electrical tape would do the job, however, it would be extremely dangerous, and you would be better off just junking it.
But if you do attempt it, always remember to unplug the TV before servicing.
Posted on Jan 28, 2009
How can i make my hamster shut up, i need sleep!?
Cover the cage at nite so it is dark inside and then the hammie should sleep also.
Jan 04, 2017 | Rodents
How do you take off and put hamster chews on kabobs
Hi Adriana,
I offer this link so you can explore a bunch of possibilities Google . Here is an Amazon link as well Amazon com super pet kabob Pet Supplies . I would cut the end. Splice through what you can, leave one less & tie knot with Para-cord. Hope this helps. Fare. Well.
May 21, 2014 | Super Pet KaBob Wood Chew Toy
My dog chewed the plug completely off my Bissell vacuum, model 61C5-W. Can I fix it myself, and where can I find the replacement cord?
The power cord should be a standard 3 wire cord. Any hardware store. Just buy the length you want. You will have to remove some covers/plastics to get to where the cord connects inside the vacuum. Look for screws holding panels in place. Once inside, you'll see how the cord is attached. Just replace the old with the new. Not critical which of the flat prong wires goes to + and - but be sure the ground wire (usually copper) goes to the ground screw and not a hot connection.
Oct 15, 2013 | Vacuums
Replace power cord Bissell Powerforce Powerbrush
Hey Shelly! Sorry to hear the dog chewed the power cord.
You may want to contact one of our Authorized Service Centers for assistance.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 09, 2013 | Bissell PowerForce PowerBrush Deep...
Puppy chewed the cord. It is an internal cord and does not plug into the back of the tv. Can I replace it myself? Directions or diagram? Where is the best place to get the replacement cord?
Any polarized power cord will work----cautions: the cord where it connects inside will have either a white stripe on one side or a rough surface---that is the neutral side---replacement must be soldered to correct points---you get it backwards and set will work but shock hazard will exist-------if you have enough cord left you can do a splice repair-----I cut them back and offset so not next to each other(the two sides of the cord----get some heat shrink tubing--slide it over each side and down a ways---solder the two ends for each side back together (you will lose a little of the cord) and once soldered slide the shrink tubing down over the soldered parts and heat it with a hair dryer and it will shrink air tight over the solder connection's---you do not want the splices side by side to prevent any possible short----for extra protection once done use some black electrical tape and tape the whole area.
Either replace entire cord or splice repair it. Examine cord end to end for any bare wire showing---if chewed in more than one spot replace entire cord.
Nov 08, 2012 | Philips 32PFL3505D 32 in LCD TV
I replaced the fuse on my Hisense TC2108D TV, but now its show EEPROM ERROR PLEASE CHECK
it due to EEPROM IC fault the iC is 8 pin and mark as 24CXX here XX -is 02 ,08 or 16 like that
just replace new one and see the error cord some time you need programmed EEPROM to resolve the problem
Aug 25, 2010 | Hisense TC24FS2H TV
I have a TC24FS2H and it locked, how do I unlock it? Thanks There is a blue screen with a lock in the corner.
Hi, tahnk you for visit fixya. Try this: ( two step)
1.--Unpluged power cord, push pwr button ( hold), connect the plug to AC line and wait for power up, release power button.
2.-- connect power cord, press power button, hold for 15 seconds, release power button.
Let me know if this work ok?. Any questions, I will be here. Thank you
Dec 05, 2009 | Hisense TC24FS2H TV
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
Hotpoint rfa70 fridge seems not to be staying cold
just give it time as the freezer has to come down to temp first
Jun 05, 2008 | Freezers
RCA TruFlat  27F520T 27" TV Logo
139 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
