Question about Radio Communications
Digipower bluetooth headset used with cell phone
This headset is seven months old. Even fully charged the blue light will not come on.
I broke my headset and need to send for repair. Where would I send this product. I have the didgpower headset model #HFBLU-HI
Posted on Jan 24, 2011
Blutooth codes for kyocera
Step 1 Charge the Bluetooth headset battery. The headset is fully charged when the indicator light turns off. Step 2 Unplug the charger and check the indicator light to ensure that the headset is turned off. If the indicator light is on, the headset is on. Turn off the headset by holding the multifunction button (the button in the middle of the headset) until the indicator light blinks red and shuts off. Step 3 Press and hold the multifunction button until the indicator light blinks red and blue to place the headset in pairing mode. Step 4 Turn on Bluetooth on your phone to start searching for available devices. When the search is complete, a list of available devices appears on the screen. On many phones, the Bluetooth options may be found in Settings. Step 5 Select the Kyocera Bluetooth headset name from the list. The phone prompts you to enter a passcode. Step 6 Enter "0000" using the phone's keypad to finish connecting the headset to your phone.
Aug 11, 2014 | Kyocera Cell Phones
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My droid 2 is not recognizing the motorola hs820 bluetooth device; I have no info on how to set the hs820 to pair
I think I can help here:
Make sure your headset and phone are charged before doing anything else. The blue light on your headset will come on when it is charging, and will shut off when fully charged.
To put your headset in pairing mode, make sure it is completely off first (no blinking blue light). Then hold down the Call button for 6-10 seconds until the blue light stays on. (It will likely flash once and shut off, but keep holding until it is all the way on and stays there!)
From there, go into the settings on your Droid 2 and access the bluetooth connections. Do a new scan for your headset if you don't see it listed, pair, and connect!
http://www.motorola.com/mdirect/manuals/QG-HS820_9494A71A.pdf
Feb 23, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Does not conect to cell phone What is the
First fully charge bluetooth.close bluetooth flip/turn on power by press button in the midle and open flip look blue light not flashing ok for pairing.if not do again and again,pairing only light stay on no flashing.
In phone go to bluetooth function/bluetooth turn on/searching devider ok/enter 4 zero ok.sucessful for pairing.
Jul 10, 2009 | Motorola Mobility HS850 Consumer Headset
Charged earpiece doesn't communicate with cell phone
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Apr 23, 2009 | Cell Phones
Reprogramming bluetooth
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 15, 2009 | Plantronics Explorer 220 Bluetooth Headset...
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
Radio Communications Logo
515 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
