Question about Bosch HMV9305 Microwave Oven
Bosch microwave fuse location - Bosch HMV9305 Microwave Oven
Bosch microwave silver edition does not turn on
check the plug see if fuse at breaker box didn't go. do you have lights? Is it in child mode ? lots to check.. including hints in the user manual.
Jul 12, 2015 | Bosch Microwave Ovens
I have a Bosch built in microwave, HMT35M653B but it went dead today. How can I get a repair manual for HMT35M653B?
Hello and welcome new user of fixya! I found a link to the bosch support page: Bosch Home Appliances Customer Service Support Repair Parts. Try giving them a call or a shooting them an email. Best of luck!
-Mr. W
Feb 25, 2015 | Bosch HMT35M653B Exxcel Stainless Steel...
Where do I find internal fuse in bosch innowave microwave
GO IN TOUCH WITH BOSCH OR THE STORE U GOT THE OVEN FROM..THEY WILL HELP U ...
Oct 17, 2013 | Bosch Microwave Ovens
Bosch microwave & exhaust fan trip fuse when on at the same time as the gas stove.
see the next steps: use the common sense and VOM
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Jul 31, 2012 | Bosch Microwave Ovens
Hi I have a BOSCH Innowave microwave only about 1.5 years old not sure of model number.... but the turntable has a massive chip out of it. Can I get the turntable replaced?
Yes! try Bosch online, they may provide a phone number or dealer close to your location, also! ebay is a great source for microwave parts, check out your local appliance repair man, and some TV repair shops.
Mar 19, 2012 | Bosch Microwave Ovens
Bosch hmt9656GB bloybf fuse
how do you change the bulb on a Bosch microwave HMT9656
Oct 05, 2009 | Bosch HMT9656GB Microwave Oven
Bosch microwave 10 amp internal fuse blown
They go once in a while Your can replace it make sure it is a ceramic fuse and the right amp.
May 08, 2009 | Bosch HME9760 Microwave Oven
Power out on Whirlpool over-the-stove microwave
Yes, There are fuses inside the keyboard panel. I would have to take a look at the manual for the specific model you have to identify the easiest way to check the fuse.
Before you go that far check above the hood and see if you can locate the plug end of the microwave. Most installations have a dedicated receptacle above the exhaust vent and microwave. It is usually a space too small for good storage so most housewives store small items and cookbooks in this space. It is usually the culprit for a microwave suddenly going out without someone placing metal inside the oven and heating it.
Heating a metal object or operating a microwave for an extended time will usually blow the fuse.
r_craig@basicisp.net
Jan 06, 2009 | Bosch HMT9626GB Microwave Oven
Sick Microware
first unscrew the unit replace fuse "near transformer this fuse is for the heating" --i think ur microwave needs a proper ventilation..
Feb 05, 2008 | Bosch HMT8625GB Microwave Oven
Mircoave doesnt trun on
Check if you are getting power to the microwave by checking the plug, and the fuses in the plug.
Dec 17, 2007 | Bosch HMT9626GB Microwave Oven
Bosch HMV9305 Microwave Oven Logo
44 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
