Fault on samsung frong loader HE2
Fault HE2
  • Washing Mach... Master
  • 17,130 Answers
Check these error codes, click Error code
Posted on Jan 21, 2013
Model WF-R125AC. Why does it wash for about 15 minutes, then displays "98 minutes error HE2"?
Hi There. HE2 is a Samsung error denoting a fault with the machine not getting up to temperature. While there's a tiny possibility that the problem is with the relay that powers the element or the main control board its self, 99% of the time this is down to the heating element failing. From what I can tell, the machine takes a fairly generic heating element and you can buy them on eBay around £20. It's a fairly easy fix once you have the element, you can probably find a video on You Tube I would imagine
Sep 20, 2015 | Samsung Washing Machines
Kenmore HE2 Plus fronload washer is showing F- as an error code. there are no numbers in the error code. just "F-" i cannot figure out what that means
press and hold the power button until the machine resets,then if machine resets, ok. but if machine shows a fault it should give a full fault code.adrian,,,,,,,
Jan 24, 2015 | Kenmore HE2 Plus Front Load Washer
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Samsung wd8704rja he2 fault
It sounds to me as one of the heating sensors are at fault. It will need you to remove and replace the faulty part or a technician to do this for you. When the lid is removed you can see two small cans with wires off them. I would think that the fault lies with this. I'm not an engineer so you can take this at face value, but check with others who may know better than myself.
Jan 06, 2012 | Samsung Washing Machines
Does not pump
hi, with no clothes in the washer fill the washer up and select drain you should hear a humming sound this is the pump working. if you can't hear it. it may be block also check the filter if it has 1 and the drain hose if all ok then there may be a fault with pump hope it helps
regards
shaun
Dec 02, 2011 | Kenmore HE2 Plus Front Load Washer
What does he2 mean on my display screen whilst a load of washing is on? the load is on now, need assistance asap.
According to my list of Samsung fault codes 'he2' means that there is a problem with the heater not working ('he1' for instance is overheating).
Sorry but a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Samsung Washing Machines
Why does my Kenmore He2 Plus front load washer not start and display an F02 code?
Welcome to FixYa.
The "F2" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although a faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...there is also a bellows at the bottom I`ll show you how to check
Oct 19, 2010 | Kenmore HE2 Plus Front Load Washer
What does F 35 mean
You could find out by removing the bottom panel on your washer and fishing out the "tech sheet". That will give you the fault codes.
Plan "B" you could retrieve the model number and check HERE to download the tech sheet that would give that Fault code. Now let me see if i can guess:d31fdad.jpegNope ain't got a clue.
Sep 22, 2010 | Kenmore HE2 Plus Front Load Washer
HE2 Plus front load washer keeps showing F21 error code. I cleared the drain pump filter. How do I check the pump and where is it located?
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris. This solution will fix your problem.
Mar 31, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
