Question about Saeco Vienna Espresso Machine
Saeco Vienna superautomatica leaks when making coffee
My superautomatica is freshly descaled, and as clean as I can get it without undoing any screws. When I pump water to flush te tank, everything is fine. When I grind and make coffee about half the volume of water leaks out under the machine. The water is clear clean and cool. Help! Jim
    Problem Solver:
  • 6 Answers
This is an easy fix for a 14$. The seal at the water tank connection is worn. Take the water tank off. There is a round flat topped plastic retainer. Pry off the retainer (comes off easily). You will see a black round o-ring made to fit on a channel. Remove the o-ring and replace.Two minutes and you are without water leaks. I do not remove the tank to fill anymore, I use a pitcher instead. Part number 3 in this diagram.
http://www.partsguru.com/user/VIENNA%20PLUS%20DIAGRAM.pdf
Posted on Feb 24, 2013
  • Richard E Semark
    Richard E Semark Jan 06, 2015
    A word of warning when filling the water reservoir with a jug, cup, etc. I did this for many months unti I accidently spilt water onto the top of the machine. The water ran into the "cooling" slots and burnt out the mother board. Very expensive accident.
  • 2039 Answers
SOURCE: Water Tank Leak
i had the same problem what i suggest to you clean where the water tank were its sit very good put the tank back me i never remove the water tank i clean regualy i put the tank empty on the machine and fill it with a glass never leak again pierre
Posted on Dec 09, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
Posted on May 12, 2009
espressonist
  • 1711 Answers
SOURCE: saeco vienna leaks CLEAR water from under the machine.
The leaking is from the water pipe coming from the boiler thought the solenoid valve to coffee group. Their are many points that this leak can be so the only way to find it is to run the machine completly open without the plastic sides. The most posible postion is the plastic hose conected on the coffee group and some times you will have to place it back in position very easy.
Good luck.
Remeber to vote for this answer.
Posted on Feb 25, 2010
EsWorld
  • 1618 Answers
SOURCE: My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Posted on Apr 07, 2010
espressonist
  • 1711 Answers
SOURCE: how do I clean my Saeco Vienna SuperAutomatica
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Posted on Jul 01, 2010
Vienna machine very scaled up can you help?
Use acetic acid based descaler. Can be bought at dealers, online, pharmacies, or from Saeco direct.
Aug 22, 2011 | Saeco Vienna SuperAutomatica Coffee...
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Water Tank Leak
Dec 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
WAter is not running through espresso and low temp
I understand that you have ran lots of water through the machines, but you need to descale the espresso machine so that you are sure all the lines are clean and not clogged.
If you need a good descaler you can purchase it http://cerinicoffee.com/Dezcal_descaler_4pack.asp
This is the descaler we use at our location.
Cerini Coffee Services, Inc.
www.CeriniCoffee.com
Nov 12, 2008 | Saeco Vienna SuperAutomatica Coffee...
DECALCIFIER
No can not. You have to waste the beans to run descaler through the Brew Group.
For Descaler or Saeco Parts visit www.CeriniCoffee.com
Nov 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Espresso Machine Logo
903 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
