Question about Toshiba Satellite A215-S7422 Notebook
Trying to use an emachines monitor with Toshiba Laptop
Will only work in safe mode. WIll not recogize monitor otherwise, receive no signal in normal mode.
    Brigadier General:
  • 5,158 Answers
Not sure if that is an added video card or a built in one... but the video driver is not working correctly..
Robert
Please take a moment to rate this solution... thanks
Posted on Jan 26, 2009
Emachines T3516 won't boot and displays "no signal" message
If you're using a VGA monitor, select to start up using VGA mode.
May 20, 2012 | E-Machines eMachines Desktop PC
Emachine - no signal
This isnt a one step fix. Power off unit then while powering on tap F8 key to get menu with option to boot to safe mode. If this works could be a driver or malware issue which can sometimes cause windows to come up in safe mode but not normal mode. This is only a start not a solution.
Dec 06, 2017 | Acer AL2216WBD LCD Monitor
My niece just called and her emachines w3507 doesn't boot,the light on the front lights and a fan comes on a little louder than normal but nothing else happens,no harddrive light or noise ,screen says no...
start ur computer press F8 rapidly if popup menu came then goto safe mode,if not then u have a problem in ur ram.but u say its giving no signal thats mean vga resolution may be not compatable with ur monitor.go to safe mode and remove ur vga driver and restart ur pc if u have a vga problem.
still u facing a problem then better chage ur ram
Mar 06, 2010 | eMachines W3507 PC Desktop
Emachine T2385 Won't Boot in Normal Mode past Windows XP Screen
The first thing I would check is your video card (usually driver) problem. Start windows in safemode with networking. If this problem has occured after updating the video card driver you may try rolling back the driver to a previous version, otherwise try
Once windows starts you'll want to go to the start menu and find and click run. In the text box enter the command "devmgmt.msc" and hit enter and the device manager should appear. Look for display adapters and left click the + and you should see your video card. Right click the video card and select properties from the drop down menu. Select thr driver tab. Now if the problem had occured after updating the driver, choose rollback the driver from the menu. If not try selecting the update driver option. After updating/rolling back the driver you'll want to try restarting in normal mode.
If it still won't start in normal mode you can try troubleshooting the video card under the general tab in properties, though to be honest I've found this rarely usefull but it might help you. Otherwise you'll want to make sure that your videocard is enabled in BIOS. A quick totorial of BIOS if needed http://www.tomshardware.com/reviews/bios-beginners,1126.html.
Otherwise it's likely a physical issue with the graphics card. Since you've tried reseating the card already it may be that the card is damaged and will need to be replaced.
Aug 08, 2009 | E-Machines Celeron 2.3GHz (rb-t2385)
Vison flat 19" hooked to toshiba laptop w/Vista no signal
Can't say I really "fixed" the problem. I tried other monitors, DVI cord and took the laptop to a repair shop. Nothing worked. And then....boom.....it worked! No one knows why or how. No one did anything to the computer or monitor. It just works. Who knows how long it will work, but it works today.
Jan 19, 2009 | TDV Vison TDV FV19B 19" Flat Panel LCD...
Black screen
- I had the exact same problem with a eMachines W340UA and other machines. I'm not sure what this does, but I resolved it by booting into Safe-Mode. Upon successful boot into Safe-Mode (without Networking), I restarted the computer in the normal mode and it for then after worked. Please try this; though I can make no logical statement as to what occurrs or what gets fixed, I have had this method work on several machines.
INSTRUCTIONS:
Fire up the machine, after BIOS postings, continually press the F8 key. From the list of startup options, choose "Safe Mode (Without Networking). It should boot up in this mode.
After the successful boot, restart the machine and allow it to boot in normal mode. If all goes as it has for me, you will successfuly boot into Windows.
P.S: If anyone knows where the coin battery is on an eMachines w340ua laptop, and hot to get to it, please let me know. Thank you and I hope this helps!
Sincerely;
Glenn T. Kitchen
admin@consultingVisions.com
Oct 16, 2008 | Computers & Internet
Emachine m5310 laptop
This generally is the indication that the hard drive has failed and needs replaced. You can try reloading the system, but 99% of the time when I see this the hard drive is shot.
Jul 17, 2008 | Toshiba Satellite A105-S2716 Notebook
EMachine laptop/windows xp problem
ur window had been crashed pls install new window
Jun 15, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
Toshiba Satellite A215-S7422 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
