Question about Intel Computers & Internet
Intel DP67BG wont detect sata hard drives - Intel Computers & Internet
chiplevel
  • 656 Answers
SOURCE: Detection & installation problem
in bios ide configration selecl ATA select both ur sata HDD will be detected
Posted on Nov 29, 2007
colliewob
  • 778 Answers
SOURCE: sata hard instalation
Do you have an IDE hard drive fitted as well.
If so remove it as I have found out that unless setup properly IDE and SATA do not mix
Posted on Nov 04, 2008
map9966
  • 2351 Answers
SOURCE: Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
Posted on Dec 11, 2008
Dudek
  • 18 Answers
SOURCE: updat to new sata hard drive from old idie hard drive.wont reconi
Hi, you will need to load the sata raid drivers when installing the OS. Some off the older versions of xp will not have these, when windows is installing it will ask if you need to install a 3rd party raid driver press F6. later on it will ask you to insert the raid driver disk. which you may have to do/make yourself if you haven't already got one.
Posted on Mar 01, 2009
Filidor
  • 28 Answers
SOURCE: Asus K8VMX board didnot detect SATA hard disk
Sounds like you just need to install your SATA drivers. Look around for your cd/floppy disc of drivers if you have any. When you boot from the CD, It will ask you if you have any other drivers you would like to install, thats when you install them and it should read your SATA hard drive just fine. If you dont have your driver CD anymore search ASUS's website or just google (or similar search engine) your motherboard and look for drivers. Beware of some phony sites though. Good luck :)
Posted on Jun 17, 2009
My computer wont boot up
check your cables,your hard drive is not detecting
May 09, 2012 | Dell Inspiron 530 Desktop Computer...
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
Not ditect SATA HARDISK
Hi
I know what is problem,some of mother is made only SATA HDD data transfer rate 1.5 GB per second.Now all are SATA HDD data read rate 3 up to g GB per second .Follow the instruction label on the hard drive.
If you use your Motherboard 3GB data read hard drive you can customise setting jumper source of data rate 1.5 then MSI Motherboard detect SATA hard drive.
Good Luck.
Nov 26, 2009 | Intel Motherboard
Connect the SATA Hard Drive to MSI VIA VT237R motherboard
go into the setupn and enable the sata settings if you are useing a ide cd drive youll have to enable both sata and pata drivs
Jul 21, 2009 | Intel Motherboard
Not decting my sata burner sometimes
i do not have the motherboard driver for this specification of motherboard
Apr 27, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Blue screen
If  you are trying to install Windows XP in latest Notebook, it will not be able to detect the Hard Drive since all the latest Notebooks are shipped with SATA Hard Drives and by default and Windows XP will not be able to detect SATA Hard Drives by default.
If you are having a Intel based Notebook, you need to download the SATA Drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36132.exe
Find the instructions to create a bootable XP Disk using the SATA Drivers from the link below :
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps...
Mar 07, 2009 | HP Pavilion dv6000z Notebook
Sata hard instalation
Nov 03, 2008 | MSI Microstar KT6 Delta (MS-6590)...
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
