Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Vl-Z1 Viewcam Camera runs fine from the adapter, but when I try to charge batteries (2 are new)..the light stays red for about 6-8 hours and then the light starts to flash red. None of the batteries seem to be charging at all. Called Sharp "tech support", which of course was totally useless and just told me to call a service provider and they want more than what I paid for the camera just to look at it!!! Anyone have any ideas on this?? I can promise that this is the very last sharp product I will ever purchase after dealing with the lack of customer support. I would think that a company would want to help the customers they have in today's competitive market, but apparently I was wrong.
  • John Johnson Feb 20, 2008
    Thanks, I bought another charger and it is working great!!
    Appreciate the help!
    Thanks!!
    I bought another charger and everything is working great... thanks alot!!
    Howtheheck
  • 48 Answers
First I have to say it seems you have a small connection problem... try changing the charger for another one or your connector . 10V with and adapter heads at Walmart for $9 dollars. Then see if it's the actual charger.. if that fails then you know it's the connector on the video camera and you can bring it for repair to a local fix it place those parts are cheap and easy to change. Takes about 20 minutes to change.. and thats after having a cup of coffee for 5 minutes.
I personally would buy a seperate charger for $29.99 and just have a rapid charge of 30 minutes for each batterie lasting 2 hours afterwards... Shower and shave and it's all ready.
Posted on Feb 18, 2008
SOURCE:
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
How can i charge my camera with no charge cord?
Yes. You will need to buy a battery charger that fits the camera battery.
Al
Mar 01, 2011 | Sharp Viewcam VL-Z1 Mini DV Digital...
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Dec 11, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
FIREWAIRE OR USB?
This camera appears to be firewire only, according to the comparison chart on sharp's website:
http://sharp-world.com/products/viewcam/compare2003.html
They call it iLink, which is Sony's term for iEE1394, Firewire is Apple's term for it.
Sep 16, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Is my camera broke?
sounds like your battery or charger might be defective. I have this camera an when the battery is to low it flashes the screen.
I still use the original charger that came with it to charge the batteries,been thru 4 of those. It seems if they set a while without being charged the go bad.
Nov 04, 2007 | Video Cameras
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
Nov 04, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp viewcam vl z1
there are mechanical problem of your camera...may be one of the motor is stuck up...check the drum motor if free wheeling..is it the common problem of that model
Aug 25, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Battery only works when plugged in
i guess so...many cases just like your the problem is always the power supply there some regulator that being busted......there a few case the only being damage is the small fuse.i hope that the only part damage to your camera..
Jun 11, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-z1 clicking
our camera was making the same noise and the repairers said it was the solderjoints had become brittle and that they needed to be resoldered
Mar 07, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
88 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
