Question about Koolatron 18 Bottle Dual Zone Wine Cooler
Koolatron wc18 light switch and temperature controls dont come on when plugged in
I have a Toyota Tundra. My Koolatron plugs into the cigar lighter but why doesn't it work?
There are any number of variations on the basic plug. Some fit; some do not. You have to decide whether to replace the plug on your Koolatron cooler or the cigar lighter socket in your Tundra. It is possible to purchase aftermarket plug and socket combinations that will resolve both issues.
Jan 06, 2016 | Koolatron *NEW* Portable Electric Cooler -...
Replacement Fuse, or Circuit Board
there are a number of repair videos on you tube. Most systems will have a fuse, probably on control board. However, they don't normally fail unless there is another issue like a bad power supply.
Oct 17, 2015 | Koolatron WC18 Dual Zone Wine Cellar
Beeping at times?
Temp OK !?? door shut all the way !?? any obstruction preventing door from sealing ?? is unit Level ??
Mar 15, 2015 | Koolatron WC18 18 Bottle Dual Zone Wine...
Why doesn't the temperatures it doesn't stay on the change I made? How do I fix this?
You don't fix it. Two weeks it is under warranty. Call for service or take it back.
May 05, 2014 | Refrigerators
Koolatron p95 cooler doesn't work in car
Check the fuse in the power plug of Koolatron unit.
Also check the fuse for your power outlet in car.
Inspect the power line, any damage, if so replace.
If the unit still does not work, you may have to contact Koolatron
Oct 21, 2009 | Koolatron P-85
Koolatron P27.motor fan open.
Parts for most Koolatron units can be found at some of the larger truck stops. Like T/A
Look in the area where they have them on display, you will see the motor and power cords.
Jul 25, 2008 | Koolatron P-85
KOOLATRON VENDING MACHINE, FAN WILL NOT WORK
customer service helpline at 1-800-265-8456
Dec 15, 2007 | Koolatron (785169015699)
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Koolatron 18 Bottle Dual Zone Wine Cooler Logo
73 people viewed this question
Top Koolatron Furniture Experts
ray gallant
John Mangan
John Mangan
Tom Chichester
Are you a Koolatron Furniture Expert? Answer questions, earn points and help others
