Question about Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover
2000 yamaha xl 800 wave runner have spark and fuel but won't start
luckyluke78
  • 333 Answers
SOURCE: the meter is not functioning
check for broken/blocked pipe to the meter and clear/replace as nessessary.
Posted on Sep 15, 2009
PWCYoda
  • 118 Answers
SOURCE: 1997 yamaha wave runner 650
Have you tried to richen up the low speed on the carb?
Posted on Aug 20, 2010
bjgarra
  • 69 Answers
SOURCE: I have a yamaha 2000
there is not enough power comming from the battery. when they get below 12.7 it won't start a motor. clean the battery terminals and cables with a wire brush(carefully, not to touch both terminals together) and charge battery with a plug in charger at 10 amps till chrger says it is good, let it set for about 30 min, and hook up and should be good.
Posted on Jan 21, 2011
co7196
  • 3433 Answers
SOURCE: does a 2000 yamaha xl
Most if not all are gravity feed because tank is higher than the carbs. The flow is controlled by a manual on off valve or is vacuum controlled. Make sure any vacuum likes going to the carbs float bowls are not cracked, leaking, or missing. Good Luck, Ned
Posted on May 06, 2011
  • 308 Answers
SOURCE: My yamaha raptor has power,
Check the compression, pull the spark plugs one at a time if more then one. If you don't have a compression gauge, you can put your figure over the spark plug hole, be mindful that before it blows it's going to **** so make sure that you don't hurt yourself leave a little gap so your figure doesn't suction down to tight. If your getting compression it should **** and blow pretty hard. If it seems to have good pressure and suction. You might need to check your timing, also make sure that you can feel air moving out the exhaust, might not be able to with the pipes on it but if it won't start and your getting everything else it needs to run gas,spark, etc. It has to almost be timing or compression.
Posted on May 15, 2011
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
Jul 17, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
My 95 yamaha waverunner 3 will crank but won't stay ctanked what's going on?
check connections clean and no breaks in wires , check solinoid and starter in good order !
Jun 22, 2013 | Covercraft Personal Watercraft Cover -...
1999 Yamaha wave runner 1200 XL won't start
Check to see if you get power to the starter when you try and start it. If you do, they you may have a bad starter. If not then you may have a bad switch or even blown fuse.
Jun 11, 2013 | Motorcycles
Have a 1999 yamaha 1200 xl wave runner when try to start nothing happens except start button lights up
Mine was doing the same thing it was the starter solenoid,may also be the starter if the motor does not crank over
Jun 11, 2013 | Water Sport
Yamaha xl 800 won't hit top speed and won't rev out to max rpm
Did the Impeller Pitch Change? Pitch will change the Max RPM, Are you Pulling harder out of the Hole than you did prior? You may have traded Torque for Top End
Apr 02, 2013 | Yamaha Xl Xlt 1200 Gp1200 800 Limited Air...
1999 Yamaha 1200GP Wave Runner wont' start. It has sat for about 2 years. I have new battery, new plugs and new gas, it turns over but won't start, any suggestions?
Sounds like the carbs are gummed up from the old gas sitting in them. Remove the carbs, disassemble, clean with a carb cleaner, and reassemble.
May 14, 2012 | Motorcycles
I have no spark in the spark plugs, motor turns over and has fuel new spark plugs have been put in
some will turn over with kill switch off so check the kill switch is working ! 2 wires , make or brake switch so try disconnected then connected as you try to start !
Sep 15, 2011 | Yamaha Wave Runner GP 800
Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
41 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
