Question about Microsoft Windows 98 for PC
I want windows 95/98 startup disk.how can i get it?
Help me?????
  • 565 Answers
  • Bob
    Bob Feb 21, 2009
    Thanks for the positive feedback and taking the time to vote.
  • Microsoft Master
  • 4,806 Answers
Hi there
Download bootable image from here:
http://www.bootdisk.com/bootdisk.htm
Good luck
Posted on Jan 26, 2009
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
Apr 01, 2015 | Dell Inspiron N5030
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
I have a question mark sign on my screen please help
sounds like your hard drive has come unplugged, you will have to remove the battery and possibly the "L" shaped metal strip then you can push the hard drive back in
Feb 14, 2015 | Apple MacBook Pro Laptop Computer with...
My desktop hp pavilion m7570n shows "disk boot failure, insert system disk and press enter" i opened monitor to check fr lose cables and just want to make sure if they are appropriately inserted. Please...
This can also mean that the operating system can not find the boot partition.
first check if in BIOS the right disk is the boot disk. You will have to push Del or F12 or other during startup. Check boot order. Choose your first harddisk to boot from and click F10 to save and exit.
If that is right and you tries all harddisks and still not booting, try to start up from a rescue disk or the original operating install disk.
for Windows:
given options: install on disk, tthen if already installed Windows found, choose repair. Choose repair startup.
Jul 25, 2014 | Computers & Internet
I need find a free windows vista home premium disk for my laptop
Download the Windows Vista startup disk .ISO file. A .ISO file is a "disk image" file, meaning that it is a compressed archive of all the files that would normally be found on a CD contained in one simple file. Microsoft does not provide users with an official Windows Vista startup disk. Because of this, a number of services online provide their own for users free of charge. Download the .ISO (see Below) file to your computer's desktop. http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/ Put a blank DVD in your computer's DVD writer. Open your DVD burning program. As long as your program can burn .ISO files, you can use any software you'd like. Burn the .ISO file to a DVD by selecting the "File" menu, clicking on "Open" and locating the .ISO file from your hard drive. Next, click the "Burn" button in your DVD burning software and the files contained in the .ISO will be burned to the disk. Label your Windows Vista startup disk with a pen or marker and keep it in a place where you won't lose it. If your computer is damaged to the point where you would need a startup disk, you won't be able to use your computer to make one. It is very important that you do not lose this disk.
Feb 02, 2013 | Computers & Internet
I turned off my computer all of a sudden before it saved settings.the next time i turned on my computer, all icons were not there and windows installer is not working. micro soft office is also not...
Maybe you can try this.....IF you have Windows 7 Operating System...AND If you have previously made an "External Start-up /Repair Disk" for your PC....While the PC is running, insert it into your external CD-ROM disk drive, then shut down/restart your PC. I have had to use this external Startup/Repair Disk several times with my Windows 7 system when it had problems...or the PC just would not boot up....and it corrected my Win7 operating system start-up system / software problems successfully. Hope fully your PC Bios "setup" is setup to go look at the external drive during startup mode to see if their is a "boot" disk in there. Your PC Manual should tell you how to change the PC Bios system Setup so that when you start it up, the PC will look at the external CD-ROM drive for the presence of a boot-up start program like the Windows External Start/Repair disk.
Hope this helps. Gary
This Startup/Repair Disk is created by the PC User after early operatation the PC operating system... based on instruction manual from the PC maker. If you have Windows 7 and did NOT make this external startup/repair CD-ROM disk...I recommend you do that ASAP...and try it out.
Oct 15, 2011 | HP Computers & Internet
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touchpad not working
What Brand is it and what Windows are you running 95,98,ME, 2000, XP or Vista? I work on the IBM ThinkPad Brands and all you would need to do is download a Driver other brands maybe the same way if they still support that model.
Jul 08, 2008 | Toshiba Satellite A105-S4004 Notebook
My computer is suddenly freezing up and not responding to some things, I've tried system restore but it didn't finnish since so much space is taken up on my hard drive, It wouldn't even show signs of...
several things to try.
1:- run disk defragmenter from start/all programs/accesories/system tools. also use disk cleanup from the same menu.
2:- remove non-essential programs from the startup menu.
3:- Add more system RAM/Memory if your motherboard will take it.
Mike @ compurepair.
Apr 04, 2008 | Computers & Internet
Microsoft Windows 98 for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
