Question about RCA BD20TF10 20 in. TV/DVD Combo
No color, only black and white
What bulbs do I need to buy to fix the problem? Thx
  • 398 Answers
If you have a good black and white picture then your tuner is fine, and tuners only cost about $25 so even if it was your tuner it can easily and inexpensively be replaced. The color in the picture is developed in the main signal IC which uses a chroma crystal. If you have correctly set the color and tint controls and the main signal IC is getting good clock and data signals and you still have no color in the picture, then that main signal IC or chroma crystal will probably have to be replaced and that should be done by an experienced tech.
Posted on Jul 19, 2007
    President:
  • 3,130 Answers
There are no bulbs inside this set to replace. This TV set is all solid state. That means it uses transistors and IC's to work. If the color is not there you could have a bad tuner assembly in this TV set and to replace that would cost you more then the TV set is worth. Sorry. Good Luck
Posted on Jul 18, 2007
Originally got blinking lights to indicate a bad bulb. Had a spare bulb that I installed. Now a very loud noise from color wheel and only a black and white picture.
Bad color wheel is cause of noise and black and white picture in tv, please replace color wheel to solve the issue.
Required color wheel is available in SamsungParts for $120
Thanks.
May 13, 2011 | Samsung HLM507W 50" Rear Projection HDTV
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
Just replaced burnt out bulb in Infocus 4805 projector. Great picture with new bulb but only black and white. Is this a bulb issue or something else in the projector?
This is most likely the color wheel. When the bulb blows, it can damage the color wheel. The color wheel is a wheel composed of thin layers of colored glass that spins in front of the projected image. It is possible to repair it with super glue, but the best way is to try to find a new one to buy.
Dec 29, 2010 | InFocus ScreenPlay 4805 Multimedia...
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
I'm looking for a wiring diagram for a Clarion drx5675 does anyone know where i can find one? Or can someone give me the color coding to the wiring so i know where they go to, thx
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Feb 21, 2009 | Clarion RAB250D
Projects in black and white
It's probably the color-wheel problem. Maybe the color-wheel stucked because of dust and/or color-wheel sensor is covered with dust.
The simple way to check this, without reinstalling drivers or so, you just tap menu button on remote. If you will see only black-white user interface it is definitly color-wheel.
Good luck.
Nov 04, 2008 | Optoma H30 Multimedia Projector
I need to know what colors mean what, so i can hook my cd player up
Red - Power
Yellow - primary power must be joined to the red
blue - Remote
Black - ground or negative
To find your speaker wires check the color of the cord behind each speaker than match it with the same color in the dash.
or the easy way is to use a normal 1.5v penlight battery and try each speaker cord behind the dash and listen to which speaker give off a crackling noise so you can get the balance on the cd player right.
If u trying to find power in the car and don't have a tester than get a 12v light or bulb join the negative to the body and push the positive wire into each one of the holes in the factory plug in the dash one at a time until the light comes on. That is your positive the rest is easy. (DIY guru)
Oct 09, 2008 | 1991 Honda Accord
Picture Problems
check for poor grounding of the input signal cable wire.
easy way to check this is put in a dvd and is that in color?
Feb 01, 2008 | Sony KP-53XBR200 53" Rear Projection...
Screen B&W only: Same as other poster
Screen works you get a black and white image. The colour stage works you get colour output to TV So my guess is the ribbon connector from motherboard to screen is loose or adrift. Is this something you fell you can fix or 'know a man that can?'
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
RCA BD20TF10 20 in. TV/DVD Combo Logo
213 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
