Question about Fujinon Techno-Stabi Jr. (12x32) Binocular
Fujiinon 14x40 stabi battery case
Broken spring connection
Dust removal inside fujinon techno-stabi binocular
The case has to be opened for this, and a can of compressed air used. There is the risk that the binocs can be knocked out of collimation, so you'd best ask a repair tech for a quote.
Sep 19, 2016 | Fujinon Techno-Stabi Binocular
Noises and cllunks going over small bumps
Install insulator on both end of the springs . Insure all connection are tight . staby links are common noise maker
Mar 23, 2014 | 1999 Land Rover Range Rover
Techno stabil 14x40 . yellow light comes on. Green light wont follow. Pwr button will not turn off pwr . of course if gr does not come on no IS
Hi.
The binocular is behavior is the same as when the electronic control module is defective. First try resetting the electronics by pulling out and putting back the AA batteries. The power reset in some occasion may unlock a jammed control module. If you have an external power adapter also test the binocular using the power adapter.
If that does not help the control board must be replaced. Disassembling of optical units is quite delicate and require experience. In that case I suggest contacting Fuji to get support. You can also get a quote on repair from a third party service. Here the online form: Repair Form.
Here some contacts. You will find your local Fujinon contact on the user manual provided with the binocular:
FUJINON INC.
10 HIGH POINT DRIVE, WAYNE, NJ 07470 U.S.A.
TEL:973-633-5600 FAX: 973-694-8299
FUJINON (EUROPE) GmbH
2 HALSKESTRASSE 4, 47877 WILLIcH, GERMANY
TEL: 2159-528545 FAX: 21 59-51 315
See also : Technical Service
Regards.
Ginko
Aug 28, 2011 | Fujinon Techno-Stabi Binocular
Fujinon Technostabi 14x40--battery compartment,clip that holds battery in place broke off,need new battery compartment
I had this problem a couple of years ago. I bought a new battery compartment from Fujinon's US repair center: http://www.bakermarineusa.com. It was about $38. Unfortunately I now have the same problem with the new battery compartment. I'd like to find a source of the metal spring clips.
Nov 28, 2009 | Fujinon Techno-Stabi Jr. (12x32) Binocular
Broken rubber seal on batterie cover
Goto auto shop. any name. grab a tube of permatex, blue red don't matter. this seals better then sillacone. sronger lasts longer. put a vare thin bead around the cover. NOT to much abut the same as the old seal. Now let that sit over night, be for putting it back together, or it'll be a real pain opening it back up. this will keep everything out. I've dun this more then once. good luck.
Mar 20, 2009 | Fujinon Techno-Stabi Binocular
WILL NOT TURN ON
There are generally 2 causes for this symptom.
1. The input connector is usually a 3 terminal device. When the plug is inserted into the device, a spring loaded contact is pushed away from another terminal which effectively disconnects the battery section from the device. This stops any electricity from the plug from being connected to your batteries and causing overload conditions. If this spring loaded terminal has been damaged, when the plug is removed from the device it will not "spring" itself back to its terminal and the battery power will not reach the PC board.
2. The battery case (compartment) has 2 wires going from it (internal to the device) one black and one red. If either of these wires has broken off the battery holder or broken off the PC board within the device, it will not power up.
You can also make sure that all the batteries are inserted in the correct direction. Since the unit works when plugged in, you can cross out anything else having to do with the unit.
Mar 06, 2008 | Radio Shack Pro-97 Handheld Scanner
Batteries contacts
I have damaged battery contacts and ITT no longer handles repairs.
They told me to contact
AE Optics
817-546-0993
Dana Prather
Jan 16, 2008 | ITT Night Mariner 160 Monocular
Repair Techno-stabi binoculars 12X32
I have a set of Minolta pocket binoculars. One side rattles and is hard to see out. One side gets great vision. Where can I get this repaired. They are the set with the zoom.
Aug 15, 2007 | Fujinon Techno-Stabi Jr. (12x32) Binocular
Fujinon Techno-Stabi Jr. (12x32) Binocular Logo
37 people viewed this question
Top Fuji Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Fuji Optic Expert? Answer questions, earn points and help others
