I put a new AA battery in my seth thomas 1502 wall clock but it wll not work. Do I have the wrong kind of battery in it?
2 Suggested Answers
SOURCE: seth thomas autoset wall clock not functioning.
I wish I had a solution... I'm in the exact same situation. I put in new batteries, and all I get is a faint reading of gibberish from the LCD screen, and that's it. I've tried following the instructions, but I can't set the time in the LCD clock, since it's unreadable, and almost completely gone. Seththomas.com has a web page indicating that "they will be back with info", but no support or FAQ pages. Disappointing... I have three of these clocks, and they are all behaving the same way.
Posted on Jun 10, 2010
Manual for Seth Thomas Grandfather clock model # 46978
Hello
I've Seth Thomas Grandfather 46978 clocks' user manual with me. But I don't know how to send it to you. It is in PDF format. The newly hoilsted Fixya site has no facilty to send the manuals to users I thinks. I can't see it nowhere in this iste. OK.
Sep 27, 2011 | Seth Thomas Radio-Controlled Howard Wall...
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
  • 3
  • 4
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    How to set
    Hello
    Mar 15, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    How to reset a Seth thomas weather station wall clock
    what do the boxes in the clock desplay mean and also i do not have an outside temp reading on the clock just inside temp and i do not know what all the buttons on the back of the clock mean and hou to use them the clock is a seth thomas sade weather station
    Oct 12, 2010 | Seth Thomas Radio-Controlled Howard Wall...
    Seth thomas autoset wall clock not functioning. replaced both sets of batteries (AA and CR2032), still not working.
    Apr 10, 2010 | Seth Thomas Radio-Controlled Howard Wall...
    Seth Thomas wall clock wont set to time.
    either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
    Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
    Open Questions:
    66 people viewed this question
     Grubhead
    Grubhead
