Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
My dishwasher just stop, the red light come on and nothing happen
I have a Bosch dishwasher (SHV 4303UC/14 / FD821000115) build in doors and I'm not sure what's wrong with it. I had the opportunity to used it only two times. It was working and then it just stopped. I am not too sure it's the power but button lights still activate when i turn it on and nothing happens Also, when it I turn it on and I closed the door, it makes a very quiet hum, yet nothing happens again.
Not sure if the problem is mechanical or electrical because nothing appears to be physically broken, but it has power. Please help
  • taj_parmesar Jan 26, 2009
    The drain pipe are not block. I did put it on different cycle and nothing happen. No water comes into the machine at all, when turn on. we checked the water connection, and the knob is turn to on position yet no water enter the system, noting happen. Help and thanks for your fast reply i really appreciate. -Taj.
  • taj_parmesar Jan 27, 2009
    Okay thanks, I'll start shopping around. and I appreciate your input.
    Regards,
    Taj
  • 74 Answers
Check the filtrs in the machine are clear and the waste pipe is not blockedput it on rinse cycle and see if it empties
Posted on Jan 26, 2009
  • Ian Jones Jan 27, 2009
    hey, sounds like you have a problem with the electrics ie: the pump, it is expensive to get an engineer but you can get a free qoute b4 you agree to the work being completed, they are cheap to replace these days it may be better to replace it, best of luck
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Jan 01, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
• If the display blinks with a "0", you will hear
no signal (indicates OFF).
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
How do you install a custom panel onto a bosch SHV
call bosch. There are specific instructions and a template they supply for measuring and attaching the panel. But that's all I can offer. Understanding the instructions is a whole 'nother' problem.
Jan 21, 2010 | Bosch Dishwashers
Dishwasher stopped. no lights, no nothing
My Kenmore just did the same thing, I verified power to the unit.
Jun 26, 2009 | Bosch SHU3306UC Built-in Dishwasher
Bosch SHV 4303 Dishwasher not draining
change your water pump or belt . Also make sure that no one just changed the garbage disposal and did not take the plug out of the disposal housing before installing the washer drain.
Good Luck
TEETERMAN
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Burnt wiring on Bosch SHX46A06 Dishwasher
Bill that is exactly what happened, the connection wasn't correct from the start. The Bosch dishwasher pulls 11 amps during the cycle while heating the water to temp. The cooler the water the longer the heat time. Your dishwasher came with a set of wire nuts that where suppose to be used. Be sure when you correct this to use 20 amp wire nuts with the unit. This will stop this from happening again.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch sms 4012 dishwasher
hiya,
Can't solve this problem unfortunately but I however have been given a Bosch sms 4012 without the manual and was wondering if you could tell me how to make it go.
Mar 15, 2008 | Bosch Dishwashers
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
258 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
