Question about Midland Radio Corporation Midland 5001Z CB Radio 5001Z
Midland cb mods 5001z - Midland Radio Corporation Midland 5001Z CB Radio 5001Z
What is the dead key adjustment # on a midland 5001z cb ?
amps like the smaller wattage so they can push out more power but some amps like the 3 watt figure so they can push out more power. go to www.cbtricks.com and look up your radio. the schematic is there but I don't remember if there is a service manual for it.
Dec 27, 2012 | Midland 1001Z 40-Channels Base CB Radio
People cant hear me on my midland 5001Z
Get a decent antenna! It DOES need to be tuned, but anything under 3 feet is practically uselss!
Sep 26, 2012 | Midland Radio Communications
Peak and tune midland 5001z
you cannot do it unless you have the proper equipment.
Jun 16, 2012 | Midland 1001Z 40-Channels Base CB Radio
MIDLAND CB RADIO 5001Z NOT RECEIVING,NOT THE MIC ,
The relay may be damaged or severely pitted. The connector may be damaged or it's PC traces may be damaged.
Also check the remote speaker plug- spray it with some contact cleaner from inside to reach the interrupt contacts and plug and unplug a jack into the socket a number of times to clean that contact.
Feb 17, 2012 | Midland Radio Communications
Brand new Midland 5001z 40 channel cb blows fuses its turned on
Where did you buy the radio at? Can you return it to the store? If you purchased it at a big box store, like Walmart, they will take it back without a receipt on an exchange.
More than likely the radio was wired backwards by someone, which blew the protection diode, and then was returned to the store and put back on the shelf.
If it is just a blown protection diode, it is only a $10 fix at most any cb radio shop.
If I can help anymore, please let me know.
Dean Pitts
Rollin CBs
dean@rollincb.com
Feb 05, 2012 | Radio Communications
Brand new Midland 5001z blows fuses immediately after its turned on. I tried the power cord on Cobra 25 that has the identical plug configuration and its Ok. I don't have the receipt as I got it a
bad final also check for any burned resistors in the area. If the final caused the resistor to burn the just replacing the resistor it would burn the new one also.
Feb 05, 2012 | Midland 5001 40-Channels Base CB Radio
How can i modify the midland 75-822 for more channels?
Modding your CB for more channels puts the radio into Ham bands which you need a license to transmit on, also modding a CB violates FCC part 95 rules and is therefor illegal to transmit with and the hams report most illegal transmitting on there band
Jan 30, 2011 | Midland 75-822 40-Channels Handheld CB...
Would like to know the proceedure for mod limiter clip and mod peak, seems to have plenty of receive with the RF Gain.
that is one of midlands big secrets. they want to do the work on their product so they will only release certain manuals for certain radios. unfortunately the 1000 z isn't one of them. Hey I mean I have a 9001z and midland told me they don't have service manuals for it.
Nov 02, 2010 | Midland 1001Z 40-Channels Base CB Radio
I need to know the wiring diagram for a telex rk56 to a 4 pin on a galaxy 88 radio
1= shield and red
2= white
3= blue
4= black
yellow-N/C
maybe this will help
Oct 02, 2009 | Magnum DeltaForce CB Radio
Midland Radio Corporation Midland 5001Z CB Radio 5001Z Logo
87 people viewed this question
Top Midland Radio Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Midland Radio Corporation Radio Communication Expert? Answer questions, earn points and help others
