Question about Ricoh Corp Aficio SP 6330N Laser Printer PostScript Kit
BYPASS MISFEED, FEED FROM TRAY IS OK - Ricoh Corp Aficio SP 6330N Laser Printer PostScript Kit
  • 183 Answers
The bypass tray does not have paper sensors, so when you print you need to specify the dimensions of the paper ion the print driver and in the machine system features-tray paper settings..
Posted on Oct 10, 2016
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Get a misfeed has occurred but there is no missfeed
Your paper may not be feeding, try your bypass tray. If that works you may need new feed tires for your cassette.
May 23, 2014 | Sharp AR-M237 Copier
No paper misfeed at ADF level but a misfeed message still displayed on my Bizhub c450
Well then check the paper draws and bypass tray. have the rollers in the draws replaced or clean. Select a different tray to use.
Mar 01, 2014 | Konica Minolta bizhub C450P Laser Printer
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Nov 01, 2013 | Sharp AR-M205 Copier
Pull out the first tray and the second tray.The sensors located on the paper feed roller assy.
Jan 16, 2013 | Konica Minolta Minolta Di351 DiAlta...
Misfeed error but no paper jam in minolta di2510
Where is the miss feed detected 1,2,3,4 draw or bypass tray?
Oct 17, 2012 | Minolta DI2510 Black and White Copier
Lanier 5618. Misfeed "B"
check registration sensor actuator
Mar 26, 2011 | Office Equipment & Supplies
Misfeed from the rear tray. The rear tray feed is not working. When it tries to feed it bends the right corner of the paper and then I get a misfeed message. I can't use the printer to print 4x6 photos...
there could be a teenie piece of paper stuck in the feed path causing this to happen, you have to visually inspect and ensure it is clear. Use plain paper to test.
rollers may also contribute to problems with feeding paper its good you tried that too.
lastly maybe the photo paper is too thick for that printer?
Apr 11, 2017 | Canon PIXMA MX700 All-In-One InkJet...
Ricoh Corp Aficio SP 6330N Laser Printer PostScript Kit Logo
136 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
