Question about Tamiya M3 x 0.5mm Thread Forming Tap TAM54232
Changing washers damixa taps - Tamiya M3 x 0.5mm Thread Forming Tap TAM54232
Why won't my bristan kitchen mixer tap turn off ? Changed washer but no avail
Modern taps don't have washers, they have ceramic cartridges. If you changed a 'washer', it won't have fixed it. You can contact Bristan direct in this link
Products
Mar 21, 2018 | Food Mixers
How to stop a driping tap
Try to follow these two you tube videos and see which one applies to your style of faucet.
Good luck.
How to change or tap washer to stop dripping tap or replace the type of...
How To Fix Dripping Tap Washer Change Plumbing Tips
Aug 05, 2014 | Plumbing
Changed the washer, turned tap and dishwasher on but water won't go through to dishwasher
Might be better to check if the water is coming out of the tap. Also confirm if you are getting any error code on the dishwasher.
Feb 06, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I change the washer on a Rotec Supertub tap
Those taps are fairly hard to remove, so you'll need a big crescent spanner to remove them. I have had the same leaky tap on our supertub, but have found replacement tap washers unobtainable here in Blenheim. Please let me know if you can find any.Regards, Tom
Nov 22, 2011 | Washing Machines
Hi, we have a tapmate futura kitchen mixer tap that is constantly dripping. you used to be able to buy spare seal kits direct from the Berglen group in watford but seem to have disappeared any one out...
The suggestions above are rubbish. The problem is common with the Futura, because the spout is moved usually through 180 degrees. The kit consists of a plastic barrier washer, and o ring. Sometimes with the replacement grub screw. Tapmate was Berglen and Berglen was swallowed up by Damixa which in turn was taken by Bristan who have some spares but I don't know if they have this. Otherwise there is an overseas website for Damixa
Mar 08, 2011 | Microwave Ovens
Change a tap washer
Turn off water at wall valve under sink. Turn on tap to ensure valve is shut off. Remove tap handle. Remove cap, collar or bushing holding shaft in place. Shaft may need to screwed out to remove. Replace washer on end of shaft, then re-install parts in reverse order.
Nov 10, 2010 | Home
How do I change a tap washer in aTechnika mixer
It may not be the washer the head gear may be faulty, sometimes if you remove it and clean it with some wire wool it works again.
Jan 01, 2010 | Computers & Internet
Do we need a Y connector for our combo washer dryer. We just have one tap in the kitchen sink
If you use a Y connector to provide water to the washer it will not be able to use different water temperatures. The water temperature at both the cold and hot inputs will be whatever comes out of the tap. The washer controls cold and hot inputs separately to change teh water temperature in the machine. A Y tap will only provide one temperature (whatever the tap is set to provide) to both inputs. If the tap is a faucet you could control the temperatures manually but the machine needs to have a water supply at both of its inputs.
Dec 08, 2009 | LG WM3431H Washer and Dryer
Change tap washer
hi first turn of your water to the tap open the taps to empty water your mixer tap con now be pushed down and twisted to come out
Nov 10, 2009 | Home
Tamiya M3 x 0.5mm Thread Forming Tap TAM54232 Logo
82 people viewed this question
Top Tamiya Home Experts
john h
Tom Chichester
Are you a Tamiya Home Expert? Answer questions, earn points and help others
