Question about Water Heaters
I just want to replace my element & can gewtinfo by phone sowhat gives
  • Water Heaters Master
  • 5,089 Answers
1) Copy following link for step-by-step how-to replace water heater element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) Add comment Jan 2013 and say what you are doing.
Posted on Jan 21, 2013
I have a rheem model 71-52b d that only produces hot water for a few minutes.could it be an element problem or should it be replaced?
Thermostats or elements...ohm the elements out & check voltages from the upper & lower stat.
Dec 15, 2013 | Water Heaters
E1f50rd045v
For residential water heater, 30 amp is best... but must have 10 gauge wire.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Color-codewire.html
If you have 12 gauge wire, then use 20 amp breaker and install 3800 watt elements in place of 4500 watt elements
Add a comment and say which size wire you have
May 16, 2013 | Water Heaters
No hot water from my Rheem 72-40-1, I replaced the bottom element a couple of times now in the last 4 months. I replaced the bottom element last night and for the first time opened the top cover to see...
Open following link to look at thermostat wiring
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
If you have dual element electric water heater, then that is a 240Volt water heater.
http://waterheatertimer.org/240-v-water-heater-circuit.html
If you are replacing lower element several times, are you also cleaning out the tank?
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Are you installing same wattage element shown on label on side of tank: Should be 4500Watts.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
If upper element burns out, then tank will have no hot water:
http://waterheatertimer.org/How-it-works.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Rheem Water Heaters
Can i replace 4500watt elements with 5500watt on a 606 model
1) Manufacturer's warranty will be voided, and I've never seen recommendation that suggests better heating or saving money from replacing 4500W with different wattage element.
2) That being said, you have 240V water heater.
4500Watts divided by 240 = 18.75 amps
5500Watts divided by 240 = 23 amps
20 amp circuit breaker with 12 gauge wire is rated for 80% of load = 16amps
30 amp circuit breaker with 10 gauge wire is rated for 80% of load = 24amps.
3) You can use 5500Watt element if you have 30 amp breaker and 10 gauge wire.
Feb 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Exactly wher eis the ele element located on an Atwood 6 gal Mod 6-E (LP & Ele)? Do you have to remove the entire water heater to replace the element? .Thanks...Richard.
There should be access from inside RV to get to the back of water heater. Make sure you have the hydro breaker shut off. On the back there is a cover where hydro wires etc, go in to. That cover has to be removed to give you access to element. Once cover is off, you should see element down low. You may want to test for voltage at element, then check switch ( on side or top of cover) and reset at ECO, (push in on little reset in center of ECO ) just in case one of them was the problem, and save changing the element.Then carefully test for voltage at element terminals. If voltage there and not getting hot replace element.
Feb 14, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Not enough hotwater cant take afull shower ive replaced elements &thermostats iset them at140 degres its a 40gal.
I suggest a complete troubleshoot:
The fact that you get some hot water says upper element is working and tank is receiving 240V.
So circuit is not suspect, and new upper element probably reads correct ohms.
That leaves 4 suspects: upper thermostat, lower thermostat. lower element, loose or broken wire located between upper and lower parts of tank.
It is possible to replace lower element and not clean out sediment, so water is not circulating around element, and lower element is not really doing much of a job.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 10, 2011 | Whirlpool Water Heaters
Hello, I have a Rheem 81V52D 50 gal. residential water heater. I had the upper element short out. I replaced both the upper & lower elements with the 4500 watt 230v. My problem now is that the upper...
It's probably bad upper or lower thermostat.
BUT... new element could also be shorted.
OR ... original tank is rated 1500 watt elements look at label on side of tank.
I always replace both thermostats to save time.
Lower thermostat costs $10 at Lowes.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Jan 16, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 gal. elct. have 220 at both elements all the time but only one drawing?
Your testing may be off here. Or you might have special order 'simultaneous' wired water heater.
Water heaters with two elements are 240V.
Elements test for 120V at all times, but with ordinary non-simultaneous water heater, only one element at a time has 240. This is called non-simultaneous operation.
Open links below for understanding of water heater operation.
http://waterheatertimer.org/How-water-heater-thermostats-work.html
http://waterheatertimer.org/B220C.html
If both elements were drawing 240 at one time, then upper thermostat is bad, or else your water heater is wired for simultaneous operation, and one of the elements is burned out.
Your tank might be wired for simultaneous operation, if water heater was special order from Rheem, or if somebody changed wiring and set lower thermostat-and-element on a separate circuit breaker.
If you have simultaneous operation, then you would have 2 circuit breakers and 2 wires going to water heater or one 50 amp breaker with 8 gauge wire to heater. If this is the case, then both elements could test for 240V and one of the elements is bad, and thermostats are ok.
If you have ordinary Rheem water heater, then it is wired for non-simultaneous operation where only one element is ON at a time. This is called non-simultaneous operation and you can check because water heater has one circuit breaker rated for 20 or 30 amps.
Rheem elements are 4500Watts.
If both elements were ON at same time, that would be 9000Watts, which would trip typical water heater 20-30 amp circuit breaker.
9000Watts divided by 240 volts = 37.5 amps
So if upper thermostat is bad, and it is turning on both elements so they both test for 240, then thermostat is bad, but also one of the elements has to be bad.
Or test is inaccurate.
Interesting puzzle.
Dec 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water is warm
Warm water is a result of and element gone out and more than likely top element is gone out. Best thing is to replace both element's because they are not exspensive and if you replace just one it will work the other one harder and eventually go out.
Just a little information if the bottom element goes out it will give you a burst of real hot water then get cold. If top element goes out it will give you warm water then get cold.
Sep 25, 2010 | Reliance & 40 Gal Mobile Home Water Heater...
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
