Question about Numark Industries Numark NDX200 Tabletop CD Player
Does the numark n4 work with ndx200 turntables, can the link together?
How to fix a tt200 tone arm that it comes out
Your gonna have to open it up, Tighten her up.
Jul 16, 2013 | Music
I cant hear music from the headphones numark cdj 200
Since there are no headphone outputs on this unit, I'm not sure what the trouble is. Please be more specific. Thanks.
Jan 12, 2013 | Numark Industries Numark NDX200 Tabletop...
My mixer works but all the lights and the fxs went out
Hi, i wonder if you solved your problem, because i have exactly the same issue with my Numark 5000FX and i cant figure out how to solve it.
I would really appreciate any help.
Nov 02, 2012 | Numark Industries Numark 5000FX 5 Channel...
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT
Sep 21, 2012 | Numark Industries Numark 5000FX 5 Channel...
Need to find how to open a NXD200 from numark... cause i got a problem with 1 button
It's just the screws in the bottom that hold the top and bottom shells together Possibly some on the sides.
Sep 21, 2011 | Numark Industries Numark NDX200 Tabletop...
Anybody you know who restore turntables?
Most turntables require a new drive belt. The cartridge sometimes needs replacing. Cahngers require much more maintenance. Hardly anybody does this anymore... but if belt has deteriorated, that is DIY as you can find suppliers of the belt online.
Aug 18, 2011 | Numark Music
Does nat read disk
typically with these if you get a no read disk on disks you have once before known to work in the unit then you probolly need a new drive. You may try to use different types of cd's ( expecially if burnt ) owners manual might have a preferred brand in it.
Aug 16, 2011 | Numark Industries Numark NDX200 Tabletop...
Sound quility is poor on phono side vol., E.Q, channel control are'nt responding properly sound like the sound is up to high
I think that something is wrong. The phono connectors are exclusively for vinyl turntables with phono cartridges. In case you connect a cd player or other compatible source at these connectors the sound is highly destorted and the result is terrible. Could you please clarify me what audio device do you use at the phono input.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 02, 2011 | Numark Industries NUMARK M2 DJ-MIXER
Numark Industries Numark NDX200 Tabletop CD Player Logo
12 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
