Question about Whirlpool LEQ9858P Electric Dryer
Making shriel noise when running
Seems not to dry as well, have to run 2-3 cycles to dry clothes and makes a shriel noise when running.
    Problem Solver:
  • 12 Answers
I had a dryer that did this as well. I ignored it until it finally stopped running at all. Turned out the barrings that hold the drum up had warn out and there were metal filings all over the back of the dryer as well as a burn spot from all the friction.
Sadly I had to purchase a new dryer, however, you might be able to replace the barrings, but they look like it will take a repair man to do it as they are in a very hard to reach area. It might cost just as much to purchase a new dryer.
Posted on Feb 19, 2009
Why are the clothes still soaking wet after a wash cycle.
Hose could be clogged up.Take hose off and see,maybe run with hose off for a sec.
May 22, 2015 | Washing Machines
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
I have the duet whirlpool gas dryer - model #GGW9200LW1 and the barrel is making a lot of noise. It seems like one of the inside little cap is loose and the clothes aren't drying. Its taking too many...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Dryers
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Dryer is slow to dry clothes, takes 2-3 cycles of 45-50 mins.
Check to see if there is a built up of lint in the exhaust.
Keeping the correct temperature at all times inside the dryer ensures that the clothes will dry efficiently. If clothes are not drying then inspect the door seal for signs that it may be worn or damaged.
A blower wheel that is not firmly attached to the drive motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat may trip and turn off the heat circuit. A loose blower wheel will usually make a rumbling noise as well. Inspect the blower wheel to make sure that it is tight to the motor shaft.
Apr 19, 2017 | Whirlpool Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Noisy dryer not drying clothes, water found in vent tube
You either have a restriction somewhere in the venting which you say you have already checked or maybe a bad blower (fan). it may be stripped off the shaft and not pulling any air through the machine. If you run the dryer with the hose removed at the back and it dries well you have a problem with your venting. If it still takes three cycles it's a problem with the dryer. Repair would probably run about $100-150
Oct 13, 2008 | Dryers
Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company (danfrogel@yahoo.com)
Sep 16, 2006 | Malber WD1000 Front Load Washer/Dryer
Whirlpool LEQ9858P Electric Dryer Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
