Denon avr-1909 going into protect mode, even with all speakers and inputs removed. I have done the soft microprocessor restart and even opened up the unit to check for anything out of the ordinary - other than an "extra" heatsink bridge floating around in there from the factory, nothing was out of the ordinary. I am thinking it is a bad voltage regulator or (hopefully not) a bad channel. Visually inspecting the components and doing a sniff test, nothing raised concern. I have a multimeter in hand- any suggestions on troubleshooting this puppy? Appreciate the help
2 Suggested Answers
tech48
  • 624 Answers
SOURCE: Denon AVR 2106 Protect Mode
Ok,
I will will help you with this, but you must follow my instructions. These are not easy unit to repair, and your troubleshooting technic may have even caused more problems. You should never power on a receiver with connectors unplugged. Since the 15 pin connector is used for the audio signals only (CN559) you may be OK, but please do not do this anymore unless you are willing to create a lot of smoke.
Since this unit does turn on without that one connector plugged in, I will assume that you do not have a blown channel even though it is the most common reason for these to go into "Protect Mode" which is what yours is doing. They go into protect mode to keep the receiver from causing more damage to the circuits and to prevent fires.
I think the most likely reason your unit is going into protect mode is because the negative 15 volt regulator on the main board is bad. This regulator is located by ref # IC102 and is on a small heat sink in the power supply area of the main amp board. Since you have the manual for this unit you should be able to find the part number and location very easy.
The second most likely reason for your problem is a resistor, ref # R184, it is a 10 ohm 1 watt resistor and it is right next to the pre-amp board on the main board. It is near CP501 but on the other side of the pre-amp board towards the output transistors a little. Check this resistor first with an ohm meter, see if it is at 10 ohms. If not, get a 10 ohm 1 watt flameproof resistor and replace it. Then make sure everything is plugged in right and try it again.
If the resistor is good, then go to the voltage regulator, you can check it by measuring the voltage at resistors R145 and R146. If you look at the schematic for that area, you will see that those resistors are connected to both the positive 15 regulator and the negative 15 volt regulator. One side of R146 should measure -15 volts and the other side of R146 should be at 0 volts. Then measure R145. You should have +15 volts on one side and 0 volts on the other side. If the voltage you measure there is not within a couple of tenths of a volt either way, change the voltage regulator that is bad. If all you get is positive voltage on R146 and no negative voltage, then IC102.
Now you are probably wondering, how can you check those voltage if the unit is shutting off right away. Here is how. Have you meter probes in place before turn the unit on, watch the meter while is is turning on. You only need a few seconds to check each one. Check R146 first, then after the unit shuts off, check R145 when you turn it back on again. This is much safer than unplugging connectors and letting the amp idle with unbalanced voltages which could cause an extreme current draw if left on too long.
If you can not verify any problems with those two things above, then you really do need to check the amp circuits. You can do this with no power connected, but you must take out the main board with the big heat sink. Once you get it out, check the output transistors and start with the pair that is located at the inner most spot of the heat sink. The area close to the display and CNT board. That is the most common channel to go bad. If either one of those transistors mounted on the big heat sink measures shorted of very low in ohms, that is the bad channel. If you have a bad channel, there will be many more parts to replace, I will let you knwo what those are if you find any shorted output transistors. You can not check the amp circuit any other way, you will only be getting a reading across the relays if you try to check it at the speaker outputs. The speaker relays never open unless the unit comes out of protect mode first.
Let me know if I have explained this good enough for you, if not I will give it another try.
Good luck,
Dave
Posted on Dec 02, 2008
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Denon 1909 flashing red ring after 20 minutes
Well on most models red ring singals :
1 ) speaker wires touching something they should not
2 ) internal overheating, shutting down to protect
3 ) something is wrong, bring in for service.
I'm guessing it's out of warranty?
Dec 25, 2013 | Denon Audio Players & Recorders
Setup help for record player (Pro-Ject Carbon Debut) and pre-amp (ART DJPRE II) into Denon AVR-1909. I have everything setup properly, but I cannot get the subwoofer to turn on with my 2-channel settings...
In two channel mode, there will be no subwoofer signal unless you change the front speakers to 'small'. If you set the front speakers as 'large' then the full frequency spectrum will be sent to the front speakers, and none to the sub. Switching from bluray may keep the surround configuration until you restart as you mentioned.
Sep 26, 2013 | Denon AVR-1909 Receiver
I have a Denon AVR 2802. No sound output when adjusting master volume knob. When trying to solve the problem, I found out that I can achieve sound output by pressing the CH vol button and adjust individual...
try to reset. Unplug the unit, press and hold speaker A and speaker B buttons and plug the unit in outlet. If doesn't help, the unit may have a problem with microprocessor or dsp boad and need to be serviced at a repair shop.
Oct 04, 2011 | Denon AVR-2802
WHATS THE MOST COMMON AND SIMPLIEST SPEAKER CONNECTION FOR THE DENON AVR 1909
Hello,the simplest and most durable is the banana plug,while the most common is simply connecting bare wire.
Feb 21, 2011 | Denon AVR-1909 Receiver
Protection error in denon avr-3000
Do you know what caused the protection shut down in the first place? Did you short your speaker wires even briefly?
You could try to Unplug the Unit for Few Minutes, say 30 minutes and then turn it back ON.Usually that would fix the issue.
If you are going into protect mode with no speaker attached,chances are that your output Ic is in need of replacement .This is the most likely cause of a protection error that you are experiencing.I am having a bit of difficulty in locating specific part numbers but feel confident that replacing outputs will remedy your concern.For further info and parts or authorized service locations in your area I suggest to contact mfg at www.usa.denon.com/ .Click on support or call(201)762-6500.I believe that they have a flat rate service and will give you an estimate.
Still, on the remote possibility that it is just a glitch caused by momentary power interruption or fluctuation, try to re-initialize the microprocessor, a hard reset (not unless this is what you were referring to as rebooted). The reset should force the AVR-3300 to revert back to factory defaults removing glitches, errors in settings & configurations, memory & presets as well as user preferences.
* turn OFF the unit using the POWER button;
* press and hold both SPEAKER A and SPEAKER B;
* without releasing the 2 buttons, press the POWER button;
* release the 2 buttons only when the display starts to flash;
* in the event of no display flashing, repeat the process.
Should the above be not corrective, then it would be a hardware fault and not just a glitch.
Let me know, if needed further assistance.
Hoe i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 13, 2010 | Denon AVR-3300 Receiver
Denon avr 885 it automaticallyshuts off when i try to power it up
Its possible that the Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky. Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor also.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
Mar 06, 2009 | Denon AVR-885 Receiver
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Nov 05, 2008 | Denon AVR-1905 Receiver
162 people viewed this question
 Grubhead
Grubhead
