Question about Dell OPTIPLEX 745 PC Desktop
System does not support installed processor - Dell OPTIPLEX 745 PC Desktop
So I'm having a problem ... I bought a Pentium D 945, and after adding it to my system, I noticed that it gives me this : 1801-Microcode Update Error Missing or Invalid Processor Microcode Update. What...
Did you upgrade an existing home-built system, or it this a pre-built system from a PC manufacturer? Pre-built systems usually have processor-specific BIOSes in them that will only allow certain upgrades approved by the manufacturer. Home built systems where you purchase the mainboard yourself have a wider range of processor options written into the BIOS to allow for wider compatibility. The error message is saying that the BIOS does not recognize the CPU code from the specific processor you installed. It has nothing to do with the OS.
Nov 03, 2013 | Computers & Internet
53mhz system bus processor is installed this processor is not supported on this desktop board and will run at reduced processor clock speed system performance will be impacted intel r pentium iv processor...
Determine the manufacturer and model number of the system board. Locate the system board manufacturer's website. Check for a list of supported processors for your system board. If it is on the list, you may need only to update the system board firmware. If you have questions about the suitability of the processor / system board combination - contact the system board manufacturer's tech support group or technical forums that they may be operating on the site.
Do not attempt to apply a firmware update file to any system board for which it is not intended! Doing so can cause irreparable harm to the system board.
I good luck!
Sep 04, 2012 | Intel Computers & Internet
167 bios
To troubleshoot processor issues, follow these steps and test the processor after performing each one:
Notes:
  • If either the system board or processor have been replaced, reflash the BIOS to the latest level before proceeding.
  • Some computers allow the fan to stop spinning. This is not a malfunction. The fan should start spinning as the system heats up.
  1. Ensure the latest BIOS code is installed. This will correct any 167 POST errors for the Intel microcode update and "176 No Processor CPUID" post errors.
  2. Reseat the processor and the heat sink
    Note: Do not touch either the processor or system board contacting surfaces. These can be extremely fragile and bent pin damage due to touching is not covered under warranty.
  3. Verify the processor fan operation is not blocked by cables or other hardware.
  4. Verify that any replacement processor is the correct architecture for the system.
May 25, 2011 | IBM NetVista PC Desktop
HI ! I bought a new AMD phenom quad-core 9750 2.40ghz processor and Gigabyte motherboard. I m unable to install Windows and the system automatically shuts down every 20 min and sometimes runs for more...
This processor need better cooling system as it is powerful it need more power so I suggest you to upgrade your Power Supply and buy more efficient processor fan cooler. Also you should check if processor is properly installed on motherboard and there should be some special thermal grease between processor and motherboard (http://en.wikipedia.org/wiki/Thermal_grease) for better thermal conductivity
Oct 25, 2010 | AMD Phenom X4 9750 Quad Core Processor...
HI, I took dell laptop with 500gb hard disk, 4 gb ram, i5 processor. they given operating system windows 7, but i want operating system windows 2003 to install SAP. Can i get write drivers for OS Windows...
That processor runs x86 code so yes it will work, with Win 2003, Have you thought about Vmware? or Virtual PC? you could install a virtual machine, install 2003, and also, SAP, then you could have best of both worlds. Otherwise just install Win2K3 no problems... You could even dual boot, if you wanted to.
Feb 26, 2010 | Computers & Internet
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
WANT TO INSTALL WIN SERVER O/S IN COMPAQ LAPTOP CQ40-317TU
It all depends on your system specifications.
If you are thinking of installing Windows Server 2003,then try to make sure that your system meets the following minimum system requirements: 128MB RAM and a 600MHz processor, and I recommend 5Gig HDD Free space.
But if it is Windows 2008 Server, then think of having this : 512MB of Ram, 10Gig of HDD free space, and an x86 processor with minimum speed of 1Ghz, or an x64 processor with minimum speed of 1.4Ghz.
Hope this helps you out .
Jul 20, 2009 | Computers & Internet
Sound Driver install
i want download pentium dual core e5200 2.50GHz sound driver setup. plz help me
May 23, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
I hav to install sound driver in my p 4 sys.having processor 4.3g
know the manufacturer.if you know you to its web site,so that can be downloadle
Feb 07, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Changing a cpu on a compaq 5000T/REM
I've located this description when installing the pentium 4 processor on Windows XP. If you have not performed these steps this may be the cause of what you are experiencing. To save you time I've pasted the section below--> Operating System Support
Nearly all modern operating systems designed for the Intel Architecture have support for the Pentium 4 processor, although some may require specific versions or processor support files. Many Microsoft operating systems like Windows* 98 SE, Windows NT* 4 with Service Pack 5, Windows* 2000, Windows* ME, and Windows* XP support the Pentium 4 processor. Linux* distributions based on the Linux* 2.4 core support the processor. Also, many other vendors have support for the Pentium 4 Processor in their operating systems. System integrators should verify that the operating system they have selected supports the Pentium 4 processor.
Note: Windows XP or certain versions of Linux are required for Hyper-Threading Technology2 support for the Pentium 4 processor. For additional information on integrating systems based on the Pentium 4 processor supporting Hyper-Threading Technology, refer to the Integration Overview for Systems Based on the Intel Pentium 4 Processor Supporting Hyper-Threading Technology.
All operating systems that support the SSE instructions that were first introduced with the Intel® Pentium III processor will also support the SSE2 instructions introduced with the Pentium 4 processor. To experience the power of the SSE2 instructions, it is critical that system integrators install drivers and software that have been optimized for the Pentium 4 processor's SSE2 instructions. For example, for maximum system performance, system integrators using Microsoft operating systems that support DirectX* should load DirectX 8 (or higher).
Software Optimization
With specific drivers that use the SSE2 instructions, graphics accelerators, audio hardware and software, and other system resources can experience substantial performance gain. It is critical that systems also use APIs that use SSE2 instructions to achieve maximum performance. Two examples are Microsoft's DirectX 8 (or higher) and Open GL 1.2 (or higher). Most major graphics accelerator vendors have optimized drivers that use the SSE2 instructions. Graphics card vendors typically highlight support changes with new driver releases. Download and install the latest drivers (dated later than October 2000) from the vendor's Web site. Also, verify that the driver version contains optimization for the Pentium 4 processor.
Many applications also use the SSE2 instructions to experience the breakthrough performance of the Pentium 4 processor. System integrators should contact software vendors to verify support and determine version information.
System performance is greatly affected by proper operating system and driver installation processes. For example, it is important to install the latest Intel® Chipset Software Installation Utility immediately after installing most Microsoft operating systems to ensure proper drivers for the chipset are installed prior to installation of other drivers. System integrators should confirm boxed Intel Pentium 4 processor-based systems are optimally configured and integrated.
Conclusion
Boxed Intel Pentium 4 processor-based systems require proper integration. System integrators that follow the guidelines in this document will experience higher customer satisfaction by providing higher quality systems.
Please let me know if you have success with this.
Thank You, Raph30
Jan 22, 2009 | Compaq P4-M, 2.0GHz Pentium 4-M...
Dell OPTIPLEX 745 PC Desktop Logo
249 people viewed this question
Alun Cox
