Question about Linksys Wireless-G WRT54G Router
Router not blocking specified site.
We have a Lynksis wireless g broadband router and through the set-up site of our router I have specified a specific website to block, but even though it 'shows' that this site is blocked, it is NOT and full access is still granted. HOW DO I BLOCK THAT SITE?
    Guru:
  • 1,049 Answers
There are a couple ways you can do this.
  1. Check the obvious and make sure that if you are blocking by DNS name that you have included wild cards to handle any virtual hosts running on that domain and that you are blocking all ports that could potentially generate the content, not just port 80.
  2. Make sure that you do not have spy ware locally on the LAN PC's that is connecting you to the site or broadcasting content. If you are initiating contact with the server from internal PC's then your inbound policies won't matter.
  3. If all else fails and you can trace the site to an IP, you can always block the IP on your router directly for all ports, set the etc/hosts file on each machine in your organization to redirect that IP to localhost, or set your DNS server to redirect that name/ip to a fake IP internally.
Posted on Jan 26, 2009
How do I reset my security password for my lynksis wireless router.
You simply use a paper clip or pencil to push the reset button on the back. Pull the power plug, then replug in (while holding the button) for a good 30 seconds. It will erase your password and set it back to "admin" Also note, it will erase your configuration on the router. Please leave positive feed back for me.
Oct 18, 2010 | Linksys Wireless-G Broadband Router
My lynksis router can detect the signal of the broadband connection but it cannot access the internet. when u try to browse any website it always says 'Error 105 (net::ERR_NAME_NOT_RESOLVED): The server...
This sounds like the router does not have DNS settings.
Check the web configuration to make sure that the DNS settings are valid. If there are DNS servers in there, try changing them to 8.8.8.8 and 8.8.4.4 and see if you still get the same problem.
Hope this helps!
Oct 18, 2010 | Linksys Wireless-G WRT54G Router
I need a security code for my new laptop and i do not know what my current one is on my main lynksis router
There is no way to recover your code. To regain access to your wireless router, on the back of the router near the power plug will be a very small hole, should say "reset" or something similar below it, with the power turned on put a paper clip in the small hole and push till you feel it click, this will reset all the settings in your router back to factory, you will need to go back and setup your router again.
Jul 08, 2010 | Arris Wireless G Broadband Router (wr850g)
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
Lynksis Wireless Router does not stay connected to the Internet.
I suggest checking the documentation of your linksys router in the linksys site. Get the manual and that would tell you how to set it up. Regarding the router being broken, it is possible. Are you wired or wireless to the router?
Jul 22, 2009 | Linksys Wireless-G WRTP54G Router
I'm having trouble linkingto the internet from my Computer, whihc is connected wirelessly with a USB Adapter from Lynksis Compact Wireless- G USB Adapter. Basically it connects fine with my router, which...
Double check your router settings to make sure your USB wireless adapter is permitted to use your wireless connection. You will probably find this under wireless security settings. I set up my wireless routers to only allow mac addresses of devices I specify, to prevent drive-by or neighbors using my connection.
Dec 26, 2008 | Computers & Internet
No internet with wireless laptop
Check to be sure that your network connections are set to automatic(control panel->network connections then right click on your wireless connection go to properties- tcp/ip click on that and check there.
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Lynksis wrt150n .. setting
Log in to your router and select the wireless tab. Then click on wireless security. Set your security mode, encryption type and create a key that will be needed to connect to the router wirelessly. Administration tab should be right next to status tab.
May 14, 2008 | Linksys Wireless-N WRT150N Router
Router help
I just purchased a Lynksis Wireless G router from you guys. I was told that it would help me get great wireless access allover my house(mind you I do not have a very large home) The wireless device is upstairs and works perfect with my home computer, but it does not work well downstairs. Slow and crashes
What do I need to do to make this work?
May 11, 2008 | Linksys EtherFast Cable/DSL Router
I lost my lynksis befw11s4 router star up disc what can i do
There are 5 versions of this model. The drivers for your LinkSys BEFW11S4 Router are available here. You have to select which version you have and can be found at the sticker underneath the router.
Good luck and kind regards.
Oct 25, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G WRT54G Router Logo
196 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
