Question about Craftsman Sears Table Saw Manual Model 113.221770
I need a zero clearance insert for a craftsman table saw model number 113221770
I made one out of plastic glass. What do you think. Good or bad
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
Sears no longer sells repair parts for this motor, only the whole motor as a replacement part, and it is $140.00, but you can buy replacement bearings from drillspot.com the bearing needed is an Enduro 6200 zz c3
Posted on Apr 17, 2010
agent91
  • 2100 Answers
SOURCE: Craftsman 10' table saw model # 137.248830 will not start
Reset button on the motor, push till it clicks. How about the breaker? What kind of switch is it? Is it plugged in? Check this stuff out. Hope it helps.
Posted on May 09, 2010
  • 520 Answers
SOURCE: Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Posted on Jan 03, 2011
Testimonial: "Thank you very much, I'll try Sears first and see if they can help. Since it's an older saw, they haven't been much help up to now."
2 questions re Craftsman Tablesaw 137.218072 since the young men in that dept at our Sears did not know what a table saw was!
You can find a nice quality feather board that will fit your table saw from www.leevalley.com. They have one that comes with both 5/8" and 3/4" table bars and sells for about $15. I have one and it works great, Look under the Woodworking tab and type in feather boards. Look at the brand Versatile Featherboards. http://www.leevalley.com/US/wood/page.aspx?p=60022&cat=1,240,45884,60022 You may want to call Lee Valley to see if they have a zero clearance insert that will fit your saw. Otherwise, order a new insert from Sears Parts Direct. From the picture on their website I believe it comes as a blank and you will need to cut the new opening in the insert. To do that lower the saw blade all the way below the table top, install the new insert, move the rip fence over top of the insert but not over where the saw blade would penetrate, turn on the saw, and slowly raise the blade up through the insert.
e1e75b0f-dc3b-4bbe-bf84-360a611e8e41.jpg b3efb051-1d00-43f6-bc27-d2f9d84da710.jpg
Oct 02, 2014 | Craftsman 10" Table Saw
I need a fence for my model # 113221770 craftsman table saw
look at the uni9 fence by delta or the better yet from general. Delta is part poor. retrofit shouldn't be too much of prob.
Dec 28, 2013 | Craftsman Sears 10" Table Saw Extension...
Model number 137228210
Yes just make sure you have or make a new clearance plate to allow the dado to come thru
Oct 07, 2013 | Craftsman 10" Table Saw
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Aug 02, 2010 | Craftsman 10" Table Saw
I need a manual for a very old cast iron 10 inch sears craftsman table saw. Sorry, no model number
Have a look here. Given the lack of a model number, that's the best I can offer, I'm afraid.
Good luck.
Aug 31, 2009 | Craftsman 10" Table Saw
Jul 18, 2009 | Craftsman 10" Table Saw
Zero clearence isert
I'm not sure why the instructions said to change the blade in order to cut the slot. I've made several of the zero clearance inserts (for different blades) and always made the slot with the blade I intend to use it with. Of course, you need to match the inserts to the blades (I just tie wrap them together.
Aug 05, 2008 | Dewalt DW746X 10" woodworker's table saw...
Craftsman Sears Table Saw Manual Model 113.221770 Logo
57 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
