Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Will not start cycles
Hi My Indesit D41 powers on OK, has got water etc...but has suddenly stopped working. When I choose cycles 1 or 2 the first light comes on and then nothing. When I reset it, it beeps 4 times. I am pretty sure that a reset used to only beep twice in the past. Any help would be greatly appreciated! (Wife is going mad and I really don't want to spend a fortune on callouts) Kind regards Bruce
  • Bruce Steyn Jul 19, 2007
    Hiya
    I have had it powered off for a while now. There is already water in the base. When I switch it on and select the first cycle (intense), absolutely nothing happens..no motors, no sounds nothing, all that happens is that the first cycle light lights up and stays lit. The water does not drain...dead quiet. If I put the dial onto reset, it beeps 4 times.
    Hope this helps and thanks for your first reply.
    Regards
    Bruce
  • Bruce Steyn Jul 23, 2007
    Hiya
    Thanks for ll of your suggestions, took the whole thing out and checked all the inlet and outlet pipes for blockages. COuld not find any and basically gave up as it was still not working. Told my wife it is screwed and will need to call someone out. Put it all back in and it suddenly worked!? So really not sure what the problem was, but it is working again so am not complaining.
    Thanks again
    Bruce
    Sergeant:
  • 236 Answers
Is it doing the initial pump out then filling with water and stopping b4 the wash cycle? if so it may be that the wash motor has failed(you may hear a buzzing) or the pcb is faulty. if the water does not fill into the base there may be a valve fault of a supply fault. any engineer worth his salt should be able to diagnose this fault on first visit and return with a part so dont expect multi visits.
Posted on Jul 18, 2007
  • Anonymous Jul 19, 2007
    mmmm... it should pump out when you first put it on a setting.. now sounds like the outlet pump has blocked and will not pump any water out therefore will not proceed, this means a stripout of the pump/hose to check for jamming/blockages but could still be a faulty circuit board. keep me updated.
SOURCE:
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Machine not pumping out
blocked pipes or no power to pump, check in that order, but clean any filters out first, cheers
Jul 05, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 Slimline
HI THERE - I ALSO INHERITED A D41 - I HAVE JUST FOUND - SITE WHERE YOU CAN DOWN LOAD INSTRUCTION MANUAL FOR MANY INDESIT PRODUCTS - I NOW HAVE INSTRUCTION MANUAL FOR MY D41 NICELY PRINTED OUT - SEE www.indesitservice.co.uk hope this helps you too - Helen
Nov 14, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
hello mate, i bought a brand new indesit d40. plumbed it in and the 1st light kept flashing, phoned the technical centre and they said its the anti flood mechanism kicking in and preventing it from working. although water was going in it was not going into the dishwasher but filling the base and the safety feature just shut it off. said to get back in touch with comet who i bought it off for a new one because its a manufacturing problem. put the new one in and theres no problem. wouldn't have a clue how to fix it myself though.
Apr 06, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
455 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Bade
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
