Question about Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
Stroke oil ratio - Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
What is the gas/oil ratio for this chainsaw? Is synthetic oil okay to use in it?
Generally 2 stroke engines work on a ratio of 50:1
100ml of 2 stroke oil in 5L of petrol.
Use good quality 2 stroke engine oil for the mixture, Stihl and Husqvarna both have high quality engine oils, designed for more efficient lubrication and emissions quality.
Mar 28, 2016 | Garden
Need to know the ratio of gas and oil for gas chainsaw 435 16' Husqvarna
Use a ratio of 50-1 with Husqvarna two stroke oil, with other two stroke oils they recommend a 25-1 mix as they do not know the quaility of other manufactureres two stroke oil, always try to use Husqvarna oil.
Sep 25, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
I have got 26cc homelite hedge trimmer what type of 2 stroke oil do i need for it, MANY THANKS
You can use any brand of two stroke oil as long as it says on the container that it is suitable for air cooled engines and you need to mix it at a ratio of 25 to 1. Regards Phil
Apr 19, 2011 | Homelite Garden
Need fuel to oil ratio for husqvarna 223L trimmer
Here is the scoop copied from the Husky site:
Two-stroke oil
• For best results and performance use HUSQVARNA twostroke
engine oil, which is specially formulated for our aircooled
two-stroke engines.
• Never use two-stroke oil intended for water-cooled
engines, sometimes referred to as outboard oil (rated
TCW).
• Never use oil intended for four-stroke engines.
• A poor oil quality and/or too high oil/fuel ratio may
jeopardise function and decrease the life time of catalytic
converters.
• Mixing ratio
1:50 (2%) with HUSQVARNA two-stroke oil.
Hope this is helpful, let me know if it's not and I'll come at it some other way:)
Aug 20, 2010 | Garden
WHAT IS THE CORRECT FUEL TO 2 STROKE OIL RATIO FOR A 2006 KAWASAKI KX85
It all depends on what type (and brand) of two stroke oil you're using. For example, some non-synthetic two stroke oils are supposed to be mixed at a ratio of 20:1. While most synthetic oils are designed to be mixed anywhere from 36:1 to 100:1. Your best bet is to follow the advice of the folks at your dealer as to the type of oil to use - and then follow the recommended mixing ratio as detailed in the oil manufacturer's instructions.
Nov 07, 2009 | 2006 kawasaki KX 125
What is the proper fuel mixture for a husqvarna chain saw ?
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Jul 25, 2009 | Garden
Two stroke ratio
The standard ratio is 32 to 1. That equals 4 ounces of two stroke oil per gallon of gas.
Top rating Pls.
Jul 12, 2009 | 2001 Suzuki AX 100
Stihl Ts400 Cut Off Saw Carb Carburetor Air Filter Logo
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
