Question about Google Gmail
Forwarding filter does not work. - Google Gmail
  • 2 more comments
  • Moyo Lo Feb 19, 2009
    I have the same issue. In gmail you can apply filters. Depending on some criteria, you can star a message, mark it as read, delete it -- or forward it.
    Every action works -- except forwarding.
    Example: Create a filter "From: 'John'" and forward to: "other@email.com".
    Nothing is forwarded...
    Can someone help?
    I have the same issue. In gmail you can define filters and filter e.g. messages from a specific sender and define an action for it.
    The action can be to mark it as read (works), star it(works), or delete it (works). Or it can be forwarding to another address. This does not work...
    Can someone help?
  • WetNWildDude Mar 31, 2009
    I have an account with an online service that automatically sends me e-mails. My e-mail address is listed as the sender and I am also the recipient. I have tested and it appears that gmail filters do not forward messages where the sender is the same as the recipient. Is there a fix to this?
  • Bernie Thames
    Bernie Thames May 11, 2010
    Could you be more specific? What part of forwarding are you having trouble with? What type of filter are you trying to apply? Thanks for using Fixya!
I've done some testing, and it looks like the email is indeed being forwarded, but that there is no way of knowing this from within Gmail.
Even though your mail is forwarded, it will not show up in Sent Items and there will be no forwarded message in your "conversation".
Furthermore, the recipient of the forwarded email will see the original sender in the From: field and the original recipient in the To: field.
The subject line will NOT have FW: or FWD: in front.
Hope this helps.
geekrebel.com
Posted on Mar 01, 2009
How to deactivate call forwarding
Typically, dialing *73 from a landline will cancel call forwarding.
Feb 01, 2018 | Lands Phones
What could cause the engine not to stay running after the fuel filter was replaced? Even after fuel pump was replaced?
From remote site, it is hard to tell what is the root cause, and change pump was done in proper order -- you should post the problem before replacing fuel pump.
Here is what I will do, assume you can do a little by yourself.
Changing fuel filter should be easy by disconnect fuel hose (pipe) from the fuel filter . Since ASE mechanic did job in your house, I assume the old fuel filter is still in your hand. Change it back (replace new filter with your older one) to see if your car will work as before. This supposed to be done before replacing the fuel pump.
If older filter works, then you knew the new filter is the root cause. This could be resolved by replacing another new filter. If the problem appear again, leave the new filter in for over night to see if the new filter will work on the next day (you could use exiting new filter to avoid buying another filter, unless you will get a different brand one). If not, the choice is to use older one for a while when trying figure why new filter does not work.
If old filter does not wok either, then something is in forwarding fuel line between fuel filter and fuel ejection system. Then, that section needs to be cleaned. Assume the pressure is measured at connection between forwarding line and fuel filter.
Oct 05, 2014 | GMC Sonoma Cars & Trucks
2 separate accounts--need to combine
There is a way to automatically send emails sent to one email address to another.
If you want all your gmail to be sent to your yahoo mail, log on to your gmail account first, and then follow the instructions below:
To forward all new emails:
  1. Click the gear in the top right.
    a31c0031923c4e7e5c2f153531c269ede377
  2. Settings.
  3. Select the Forwarding and POP/IMAP tab.
  4. Click Add a forwarding address in the "Forwarding" section.
  5. Enter the email address you want to forward to.
  6. For your security, we'll send a verification email to that address. Open your other email account and find the confirmation message from the Gmail team. If you're having trouble finding it, check your Spam folder.
  7. Click the verification link in that email.
  8. Back in your Gmail account, reload the page in your web browser - look for the reload icon snp_473524eeb211d78ea552b2881d1a3a1e8358_6002871_en_v0.
  9. Forwarding and POP/IMAP page in Settings, check thatForward a copy of incoming mail is selected and your email address is in the drop-down menu.
  10. In the second drop-down menu, choose what you want Gmail to do with your messages after they're forwarded, such as keep Gmail's copy in the Inbox (recommended) or archive Gmail's copy.
  11. Click Save Changes at the bottom of the page.
filters.
Stop auto-forwarding
If you no longer want to automatically forward your mail, follow these instructions:
  1. Open the Gmail account that you forward from.
  2. Click the gear in the top right.
  3. Settings.
  4. Select the Forwarding and POP/IMAP tab.
  5. Select Disable forwarding in the "Forwarding" section.
  6. Click the first drop-down menu after "Forward a copy of incoming mail to" and check for any addresses listed as "(in use by a filter)." To disable the forwarding filter, choose the Remove option.
Hope this helps.
John
Jan 29, 2014 | gmail.com
Create a new email
You can have multiple gmail accounts.
Please note that gmail will always default to the last account that you logged on to.
To create a new gmail:
1. When you are in gmail, click on the account icon in the top right corner.
2. Click on "Add Account".
Once you have more than one gmail account, you will need to sign off from one one in order to sign on to another. To do so:
To get to your preferred gmail account, you have to sign out of the one you don't want.
2. Click on "Sign Out".
3. On the "Sign Out" page, click on "Sign in with a different account".
4. Here you should be able to access the gmail account you prefer.
BONUS NOTE:
Just so you know, you can have email from one account automatically forwarded to another email account.
Here is the procedure:
  1. In gmail, click the gear in the top right.
  2. Settings.
  8. Back in your Gmail account, reload the page in your web browser - look for the reload icon [img src="https://storage.googleapis.com/support-kms-prod/SNP_473524EEB211D78EA552B2881D1A3A1E8358_6002871_en_v0" height="auto">.
filters .
  2. Settings.
  4. Select Disable forwarding in the "Forwarding" section.
  5. Click the first drop-down menu after "Forward a copy of incoming mail to" and check for any addresses listed as "(in use by a filter)." To disable the forwarding filter, choose the Remove option.
Hope this helps!
John
Jan 13, 2014 | gmail.com Computers & Internet
How do I forward yahoo email automatically to another email address
You can obviously forward your emails to the other account; all you have to do is enabling of the forwarding message settings in your account. All you have to do is "click on settings":
If you are using gmail you will see "forwarding imap/pop or forwarding tab"; click on it you will have to enter the yahoo email address on which you want to forward the mails and then a verification code link will be sent to that email by clicking on which you will be able to forward the mails to yahoo.
If its outlook, you have to go for the "email forwarding tab" and enter the yahoo mail address on which you have to forward your mails and then a verification code link will be sent to that email by clicking on which you will be able to forward the mails to yahoo.
You also can set up filters to forward messages that meet specific criteria. You can create 20 filters that forward to other addresses and can also maximize your filtered forwarding by combining filters that send to the same address.
Apr 20, 2013 | Yahoo Mail
IP Camera Port Forwarding
The best way to find out what is being forwarded is to look at the traffic with the Wireshark program. You can install this from the Internet.
Wireshark is perfect for this but you have to learn how to filter traffic or there will be too much information collected. It is also regarded as (a bit of) a burglar tool so don't use it at work without permission.
I would recommend that you connect a PC to a wired port on the inside LAN and configure the router to forward outside requests to the PC. When you run wireshark on the inside PC with a filter that selects for tcp port 80 (or tcp port == 80) you will see traffic forwarded from the router.
Use your outside machine to request a page from the router's outside address and the port you are forwarding. If you have forwarding set up correctly, you should see a TCP connection attempt. If you are not running a web server on the inside PC, there will be no connection so you will only see the SYN packet from.
outside. If you have a web server on port 80, you will see a fair number of packets in both directions. (SYN -- SYN-ACK -- SYN -- some HTTP Headers an HTTP GET / a response and FIN -- FIN-ACK).
Once you see successful port forwarding (your are forwarding TCP packets, right?) at the PC, change the destination of the forwarding to the camera.
This is really technical but Wireshark is so good that it is quite easy to use.
Sep 10, 2012 | Computers & Internet
Can't receive mail
Are you accessing your Gmail account through Web or did you configure it in an e-mail client like Outlook 03/07, Outlook Express?
If you're accessing your Gmail using Web, there should be no problem. But I think that you are using Outlook. If you do, just change the Incoming port number. If it's set to 110, then change it to 993.
However, you need to check also if you set up the forwarding feature of your Gmail to forward the messages into an alternate e-mail address.
On your Gmail, click on Settings > Forwarding and POP/IMAP and
make sure that forwarding is disabled.
Have a great day!
Oct 09, 2009 | Google Gmail
How do I Enable port forwarding to port 3866 UDP and TCP to get Ventrilo to work?
1. you don't need port forwarding to get the vent client to work.
2. if you're having issues doing port forwarding to your vent server, then you need to check out port forwarding instructions for your specific device - which can be found organized by manufacturer here.
Aug 23, 2009 | 3d Rose Londons Times Funny Music Cartoons...
Mail forwarding
Through mail forwarding (as the name suggests) you can forward a paticular mail to many adresses automatically. G-Mail (Google Mail) http://www.gmail.com provides this utility free. And how to do it, ITS SIMPLE as 123 Here's how to forward messages automatically:
  1. Sign in to Gmail.
  2. Click Settings at the top of any Gmail page, and open the Forwarding and POP/IMAP tab.
  3. Enter the email address to which you'd like your messages forwarded.
  4. Select the action you'd like your messages to take from the drop-down menu. You can choose to keep Gmail's copy of the message in your inbox, or you can send it automatically to All Mail or Trash.
  5. Click Save Changes.
(EXPERTS)
You also can set up filters to forward messages that meet specific criteria. You can create 20 filters that forward to other addresses. You can maximize your filtered forwarding by combining filters that send to the same address.
Source: Google Help.
If helpfull , Do Rate ME!
Jul 17, 2009 | Computers & Internet
Port forwarding not working in ok firmware AGL6 or later
According to my very thorough testing some weeks ago, P-660-HW-D1 port forwarding is really very broken.
The worst thing is that not only does the port forwarding work properly, it lets packets to LAN addresses where they're not supposed to go. This means you're not safe behind LAN.
Firewalled or not, AGL.6 or AGL.7 shouldn't be used at all in my opinion, they're unsafe. When in routing mode, and having several LAN machines behind one Zyxel switch port (i.e. separate switch attached), I found that the port forwarding is completely broken.
I have contacted Zyxel Finland about this issue two weeks ago, and they initially thanked for the finding and said they're passing the issue onwards and investigate it.
The best current solution is to downgrade to (also very buggy) AGL.4.
May 13, 2009 | Zyxel P660HW-D1 Router
Google Gmail Logo
370 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
