Question about Hotpoint WF430 Front Load Washer
Belt too tight to fit
We are trying to fit me belt on washing machine. It is really too tight to fit, any tips??
  • 2,920 Answers
The belt has to be tight so that the machine an work you have to get it over the pulley and it will work use a screw driver if you need to as a kind of prybar for it
Posted on Jan 26, 2009
  • 86 Answers
The easyest way to fit these belts is to locate it on the motor pulley and as far onto the right hand side of the main pulley (viewed from the front of the machine) as possible. Hold it on the main pulley with a cable tie and rotate the drum anti clockwise by turning it from inside. The belt will be drawn onto the pulley and the cable tie will snap as it rotates. (Easy)
Posted on Jun 25, 2009
I need to replace drive belt on a whirlpool 5300xkwo. do i need to drop motor out to install belt. it is really tight and am not sure if i can reinstall without disassembling.
The drive belt on a F/L washer is normally quite tight and when installed will need to stretch slightly to maintain it's tension.
If you have the correct belt you should be able to make it fit by fitting it onto the motor pulley and then holding it onto the large pulley while at the same time rotating it to get it in place.
Make sure you have the correct belt by checking the belt length. The belts will have a series of numbers which should compare, even if the brands differ.
A belt which is too tight can cause the motor bearing to fail prematurely.
Good luck.
Cable ties can also be used...
Mar 08, 2015 | Whirlpool Washing Machines
I have a whirlpool cabrio washer and the belt has came off during a washing cycle. I have tipped the washer over to check to see what was wrong and the belt came off. The cover has cuts in it where th
rarity but belt could be stretched does the big pulley turn freely is it tight is the motor tight if everything is tight and spins freely try a new belt
Feb 12, 2015 | Whirlpool Washing Machines
How do I take the back off my wt540? I am trying to replace the belt
unfortunatly the back does not come off this machine, only the small inspection panel at the rear.
belt can be really hard to fit, hotpoint actually supplys its engineers with a specialist tool to fit the belt.
i fit it by removing the lid and inspection panel, fit belt around motor first then from the top feed onto the drum pulley. a tip is you can cable tie the belt to the main puley(use a few) then slowley rotate and belt should slip on, sort of like putting a chain on your bike.
may take a few trys, good luck with it and let me no how you get on.
Jul 06, 2011 | Washing Machines
How do i fit a new belt in the washing machine
Hello,unplug appliance, remove lid and back plate, place belt on motor and carefully on drum pulley, turn pulley to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Aug 19, 2009 | Washing Machines
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Jul 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi Aqualux washing machine
the belt is a tight fit so you need some strength
remove top. loop belt over the motor pulley and start belt onto drum pulley. turn drum pulley and belt will work its way on. there is just enough room to do this
Oct 08, 2008 | Zanussi F1045W Front Load Washer
I need to change the drive belt on a Tricity Bendix 1200 washing machine. I have got the top of and can see the hole at the bottom of the machine but can't reach where the belt fits.
the belt goes round the motor spindle at the bottom. tape belt to large pulley. tilt machine backwards and put belt over motor shaft and tape into position. start belt onto main pulley and turn it so belt eases on. it is a tight fit
Jul 22, 2008 | Washing Machines
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Jan 23, 2008 | Zanussi F1045W Front Load Washer
Belt fitting for a WF000 hotpoint washer?
It should go around 2 wheels; one is the pulley of the motor, where there is a good groove. The other goes around the tub wheel which is big one. First fit to the motor wheel then fit to one side of this big wheel & turn the wheel to engage it gently. The belt should have a "give" of only half an inch, or it will be too loose or too tight.
If helped pl rate.........
Dec 28, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF430 Front Load Washer Logo
274 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
