Question about Maytag Neptune MAH5500B Front Load Washer
Cant get the belt on
I cant get the belt on the drum or motor.is treir a tensioner?
  • 112 Answers
If you have a tensioner, the pump will be bolted to it.
If not, thread the belt round the wheel on the drum and hold it as though you are going to put it on the small motor pulley wheel.
Spin the drum slowly by hand and let the belt feed onto the motor pulley wheel.
It`s just like putting a bicycle chain on when it`s come off.
Hope this helps you
Posted on Jan 26, 2009
Frigidaire dryer fde564les0 belt wont stay on. New belt and tensioner assembly
cant trace model number please verify and post.. until then make sure drum turns freely and that idler arm is aligned strait with groves on motor that belts is on groves down
Jan 07, 2015 | Dryers
Im trying to replace the drum belt on a Miele t7734 tumble dryer, but cant seem to get around the front or back of the drum to get the belt around it. Am I supposed to dismantle the whole machine to do...
Some dryers disassemble from the front, making it possible to slip the replacement belt over the drum and connect it to the tension idler and the motor pulley.
Dec 20, 2014 | Miele Dryers
What's your problem?i am trying to fit a drive belt to a hotpoint wma66p washing machine but cant stretch it around motor pulley and drum. i cant see a tensioner bolt. is there one?
There is no tensioner bolt as such; tension is just maintained by the motor support bolts. Please see my notes on belt changes ;-0)
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT AGAINST THE MOTOR OR FRAME; THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 23, 2011 | Washing Machines
Top loader Speed Queen takes long time to complete one wash.
sounds like your belt is worn or the tension spring too tight on belt the vee part of the belt should not be rubber it should look like a material type coating to let it slip until it gets up to full speed (It,s Meant to slip) If it,s worn the rubber in the belt will grip too much.Hope this helps.Cheers.
Aug 06, 2009 | Washing Machines
Motor not turning drum but heaters working ok
Your belt may be stretched and is slipping on the motor pulley.Belt tension pulley may be sticking. May be a bad lint buildup on the blower wheel.
And yes, finally, maybe a bad motor.
Jul 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Cant figure out how the belt tensoner works to hold the belt tight i have a kenmore 70 series electric dryer
There are 2 slots underneath the motor pulley.
The flat part of the tensioner goues in these slots.
The roller wheel will then be on your left.
With the belt around the drum, run the belt under the wheel and through the tensioner, then over the motor pulley.
Mar 14, 2009 | Kenmore 62802 Electric Dryer
How do i change belt
Take off the back of dryer. There should be a panel with about 6-8 screws in it. You will put your hand towards the middle of the drum on the outside and feel a groove. This is where the belt will ride. Just slide the belt over the drum and into the groove and then around the pulley on the motor. Your particular model may have a tensioner device on it that has a pulley on it as well. You would trace the belt on this pulley as well. Put the belt against the pressure side of the pulley. This would give it tension on the belt at all times. Let me know how you do with this.
Feb 08, 2009 | Whirlpool LER4634J Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Maytag Neptune MAH5500B Front Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
